bnitch Posted August 30, 2015 Author Report Posted August 30, 2015 Why not make the holes a more standard size, such as M2. Screws and standoff's in 1.6 or 1.7mm are so hard to come by. Even #0 screws are limited in length availability. If you don't want to use a face plate you are in for a tough time.
mikepetro Posted August 30, 2015 Report Posted August 30, 2015 Cant answer to their decision on size, but 0-80 screws are ready available in sizes up to an inch long.http://www.mcmaster.com/#machine-screws/=yq29id
turbocad6 Posted August 30, 2015 Report Posted August 30, 2015 it's all about miniaturizing everything as much as practical, screw terminals for the wire connections and a push in replaceable fuse would all make things easier to deal with too, but space is a primary concern
bnitch Posted August 30, 2015 Author Report Posted August 30, 2015 #0-80 turned up much better of a selection, I was searching under #0-42 and 1.6mm ( as the diagram showed hole size to be 1.7mm ) and was coming up short. Had not seen anyone mention that size up to this point.
turbocad6 Posted August 30, 2015 Report Posted August 30, 2015 Just picked up some 0-80 and 0-90 screws and nuts and #0 wood srews at my local hobby store, anyplace that sells model trains should have stuff like this i think if you dont want to wait for delivery
mikepetro Posted August 30, 2015 Report Posted August 30, 2015 bnitch said:#0-80 turned up much better of a selection, I was searching under #0-42 and 1.6mm ( as the diagram showed hole size to be 1.7mm ) and was coming up short. Had not seen anyone mention that size up to this point.From FAQ said:The board attachment screws are 0-80 round head .1875" long stainless steelIt is in the FAQ . You might want to take a look at it, lots of good info in there.
bnitch Posted September 2, 2015 Author Report Posted September 2, 2015 I'm putting them in wood boxes so the Screws need to be flat head and I just need to find the right length of standoff's from inside face of box. Maybe I should have just said there are way more M2 standoff's than anything smaller.
blueridgedog Posted September 6, 2015 Report Posted September 6, 2015 It is an interesting observation that we are getting to a wire size where screw terminals for the wire would be an interesting alternative.
