Logan314 Posted September 10, 2015 Author Report Posted September 10, 2015 In my DNA mod the firing button does not always fire when pressed, it is also randomly locking without pressint the firing button 5 times in succession. Any insight as to why this may be occuring?
blueridgedog Posted September 10, 2015 Report Posted September 10, 2015 Usually that is a button that fights tight in the case or gets jammed or finally is too tight against the tactile switch.
Logan314 Posted September 10, 2015 Author Report Posted September 10, 2015 It has worked flawlessly for the 2 months since i built it and just over the last few days has it been acting up. Maybe i will take it apart tonight and check it all out.
Patrick.N Posted September 10, 2015 Report Posted September 10, 2015 Perhaps those small membranes inside your tactile needs a cleanse or replacement, tactiles have more cycles than vandalswitches but check it as you can open them but gently
blueridgedog Posted September 11, 2015 Report Posted September 11, 2015 Or the display ribbon cable has moved to the point where it is interfering.
scoopy Posted September 11, 2015 Report Posted September 11, 2015 I have the bigger size 3d print box like that and had to adjust the board screws a little to keep the buttons from firing......try loosening up the top 2 board screws a little......also the battery fits very tight in there sometimes pushing down on the board to much.....like the others above have said check to make sure your buttons move freely in and out there respective holes and sand them if need be
