How to change the fuse ?
David247
soz for been slightly off topic but the strangest thing just happened while i was swapping the batteries in my boxer 133. as i slid the first new battery in to the mod there was a crack and the mod was dead but after leaving it a while it started to work again.if someone could explain what happened it would be appreciated.
thanks for the earlier suggestion to what the weird cracking noise was ,it turned out to be the chip shorting out from one of its corners because of something to do with the fact it was running of 2 18650 and apparently it was trying to take a too higher voltage.shortly after my last  post it stopped working and its due back from the shop tomorrow.
