Adding a custom charging port
NickIcon
I'm in the process of designing a custom DNA 200 box mod and am thinking of making a charging stand for it as well.
Originally I had been thinking of using an inductive charging module a-la VaporShark rDNA40. Given that I would be making something on the bottom to align the mod on the stand anyway it seemed like a better idea to turn those into the contacts rather than bundling in the extra wireless charging components.
Here's the concept so far:
The mod has matching female contacts on the bottom: two grounds on the outside and live in the centre so that the mod can be put down on the stand either way around.
The priority is to make the connection easy to make so I've dropped the idea of moving the mod-side USB port to the bottom: I don't want the mod to "stick" to the stand when it is removed and I want to avoid having to align the USB connectors (and then push down) when it is placed on the stand.
Of course this means that the stand will serve to charge only and that the USB port will still be required to connect to a computer to use Escribe but where day to day use is concerned I'm more than willing to make that sacrifice. On that note however, I'm sure that the on board USB connector could be removed and all contacts re-routed to a custom connector with all 4 USB contacts but I'm reluctant to make any changes to the board itself.
My intuition says this shouldn't be too difficult - find the positive and ground that the USB connector connects to on the board and solder on the leads to a connector on the mod that fits to the stand.
On the other hand my understanding of electronics is limited... Other than not having the mod connected via the USB port and the to the charging stand at the same time, can anyone enlighten me as to whether this would work or not?
The follow-up question is where to solder on my leads to the mod's stand connector - without compromising the existing USB port.
Any help would be much appreciated!
I am loving this.  I was thinking of doing the same thing, and to see your progress so far is really great.  As far as the two points on the board that are for + and - in for USB, I checked, and as far as I know you will have to go the points right at the USB.   I'm pretty sure the way I have them marked in this picture are correct (may have them reversed).  Send 5 volts there and I believe you will be good to do.  (You will also notice that the USB is made up of 5 contacts all together).
Please do not take what I'm saying as fact, as I have wondered these same questions, only did not get far enough to ask evolv specifically.
Expand
Yes, would work. If you give 5V to the USB on Vbus and ground to the DNA, it will be happy to charge. The connector design could use magnets or just the weight of the mod and gravity to make a good connection. You would need to include either an electrical or mechanical method of preventing backfeeding a computer supply if accidentally connected to USB while on the charger stand. The design of the stand itself could easily incorporate a shape that would preclude mating the contacts while a USB cable was connected. Here's the pinout diagrams (jump to the pinouts section). https://en.m.wikipedia.org/wiki/USB#Mini_and_micro_connectors
Expand
That does look much easier than digging up the tracks in the PCB, although I may have to wait until my DNA200 actually arrives to get an idea of whether it'll be feasible - still looks very small!
I was planning to omit the "ID" pin - I didn't think it would be required but a second opinion would be appreciated.
  NickIcon said:
[QUOTE=vaporlips]
Expand
I was planning to omit the "ID" pin - I didn't think it would be required but a second opinion would be appreciated.[/QUOTE]
You have to remove the USB socket to get to where he put the arrows.
Expand
It has just been suggested to me that copper contacts may get gunked up quite quickly with any arcing  - magnets sound like a great idea!
  VapingBad said:
[QUOTE=NickIcon][QUOTE=vaporlips]
Expand
You have to remove the USB socket to get to where he put the arrows.[/QUOTE]
Oops - yes, I see it now.
I'm starting to think I may have to leave this until the mod after this!
