xtremeo07 Posted October 22, 2015 Author Report Posted October 22, 2015 I have been trying to figure out how to get the 14 gauge positive wire to solder into a fatdaddyvapes V3 510 pin. It doesn't fit perfectly and some strands always poke out of the solder join. Any suggestions?
Mad Scientist Posted October 22, 2015 Report Posted October 22, 2015 xtremeo07 said:I have been trying to figure out how to get the 14 gauge positive wire to solder into a fatdaddyvapes V3 510 pin. It doesn't fit perfectly and some strands always poke out of the solder join. Any suggestions? Strip the wire about a half inch or more. Twist the strands together so they are smooth and tight together and then tin the wire. Snip off the excess length after tinning. Then insert the wire in the pins's solder cup and solder. I've gotten 12 AWG in there so 14 should fit. I know you already have the FDV but the Varitube 510s are definite better and cost about the same.
blueridgedog Posted October 22, 2015 Report Posted October 22, 2015 Building on Mad's reply...if you have stands you are not tinning your wire, which will get you into trouble in many other assembly areas.
xtremeo07 Posted October 23, 2015 Author Report Posted October 23, 2015 I appreciate all the help and will try the above tonight.
bnitch Posted October 23, 2015 Report Posted October 23, 2015 Or you could just use the minimum of 16awg, that fits fine.
