I just bought a Lavabox. When i recieved it i recogniced that there is no battery icon on the screen and i can't fire the mod. I removed the battery from the box and put it back in, then the battery icon was visible and everything worked like a charm. Then i just let the mod sitting on my table for an hour or so (fully charged). When i came back and wanted to use it the battery icon was gone again and the mod didn't fire. Removed the battery again, put it back, everything's fine. After a while the same problem appeared - no icon, mod won't fire. What's wrong with my device?
Thanks a lot for your reply. I'm at work now so i can't check escribe. But it's definitely on "3 cell", i checked that already. After removing the battery and putting it back everything seemed fine in device monitor.
Isn't the lavabox pre-configured so watt hours etc. should be set correctly?
So i checked escribe now and changed the capacity from 8 Wh to 9.9 Wh (3-cell). I also changed the cell soft cutoff from 3.66 to 3.3 V.
Type is LiPo, charging mode is "maximize puffs".
Here is what the device monitor says:
Cell 1: 4.03 V
Cell 2: 4.02 V
Cell 3: 4.03 V
Are these settings ok?
Unfortunately changing the settings didn't help. I didn't use the Lavabox for an hour and now the battery icon is gone and when i fire the mod it just says "check battery". The the screen goes off and the device is locked.
Some ideas what to do now? Thanks for your help, guys!
