Blazinlo93 Posted November 22, 2015 Author Report Posted November 22, 2015 DNA 200 won't vape past 135 watts. I'm running standard kanthal dual coils 0.53 ohms. Is this normal?
retird Posted November 22, 2015 Report Posted November 22, 2015 Blazinlo93 said:DNA 200 won't vape past 135 watts. I'm running standard kanthal dual coils 0.53 ohms. Is this normal?Look at the Output Power section in the datasheet.http://www.evolvapor.com/datasheet/dna200.pdf
Blazinlo93 Posted November 22, 2015 Author Report Posted November 22, 2015 If I'm reading it right I should be able to go full power, so is it safe to assume there is something wrong with the board? I have made sure the max output for kanthal set to 200 watts in escribe.
retird Posted November 22, 2015 Report Posted November 22, 2015 Blazinlo93 said:If I'm reading it right I should be able to go full power, so is it safe to assume there is something wrong with the board? I have made sure the max output for kanthal set to 200 watts in escribe.Doesn't the chart show .53 ohm's to max way below 200 watts.... approximately 130 or so watts...?
Blazinlo93 Posted November 22, 2015 Author Report Posted November 22, 2015 Sorry I had zoom in a lot to see it, yea I believe you are correct. Thanks!
black lace Posted November 22, 2015 Report Posted November 22, 2015 Thanx from me to i wondered what thoes pictures were about lol
