what if you got some of that quick evaporating electronics aerosol spray and sparyed the whole friggin board down. didn't you spill sumthin on it? i just dont see two batteries doing the same thing. all your resistors still on the balance part of the board?
I did do something on that order but just the usb and below, not going to say what chemical though. I did clean the 4 balance connector joints the first time with a q tip and alcohol but that must not have worked.
OK here's what I cleaned it with, twice, then duster spray.    http://www.ebay.com/itm/NO-CLEAN-LIQUID-FLUX-FOR-PS3-YLOD-XBOX-360-RROD-REPAIR-/130498300452
Something was draining #3
I guess I'd better mention that the area that I was concerned about it conducting is between pin #3 and pin #2 on the board underneath the white plastic balance connector.
I just got my original (unbalanced) Vapecige battery back from my friend that tried to balance it with his BA6 RC charger with no luck. He did balance it though using the same method I used. So far my (Turnigy) battery in the Vapecige box is staying balanced.
[image]
Trying to do this as I have ANOTHER bad hotcig battery, cell 1 will charge to a max of 3.85V, while cell 2 and 3 fully charge. This mod has been nothing but trouble, can't wait for the Wismec Realaux to come next week :)
I can't even get the charger to recognise I have a battery inserted (Nitecore D4). 'Bennett' from hotcig asked for my name and adress and said he is sending me a new DX200 on Monday, hopefully he keeps to his word.
OK-I rigged it up the same, and it IS making the voltage climb, I got to 3.95, but then thought I will do it when cell 2 and 3 is at say 3.95V, then get cell 1 the same, and hope it charges in escribe. If not I guess I will have to go to the full capacity carefully watching the LI-PO.
and would you believe it-I pulled it at 4.16V, am finishing with the wall charger and its at 4.18V, so I think once charged, it may well work. I am a bit worried it will get stuck at 3.86-90 again, but now its been charged past that I don't think it will.
If this works, I will be one happy bunny. The battery bar has already shot up from what it ever was-So that bodge job wiring from my Li-ion charger to the balance ports of cell 1 may of worked.
I am happy now, will have the true life I expect from it :).
EDIT: Woop its hit 4.20 on normal USB charging. Just to find out if it charges past when I have discharged it.
