bnitch Posted November 4, 2015 Author Report Share Posted November 4, 2015 What does the board temp run lets say cold and under normal use with a tank 50 wats at 470 deg. I know it will differ just trying to see if one board I have is screwy. Link to comment Share on other sites More sharing options...
cukrus Posted November 4, 2015 Report Share Posted November 4, 2015 leave it for 5 hours and the temp will be the same as room temp or a few degrees higher. on usage i reach around 86f Link to comment Share on other sites More sharing options...
KwiqNiss Posted December 3, 2015 Report Share Posted December 3, 2015 I'm using a quad coil grade 1 titanium, 26AWG, with 3.5mm wraps, 5 wraps, quad coil near .08 ohms resistance, and it's near 125F. I'm at 100W with temp control set to 500F. The case feels warm though. Anybody know what max safe temp is for the board? Link to comment Share on other sites More sharing options...
black lace Posted December 4, 2015 Report Share Posted December 4, 2015 data sheet only says ;;Too Hot: The DNA 200 has onboard temperature sensing. It will shut down and display this message if the internal board temperature becomes excessive. Auto;;my case gets very warm, the atty gets very very warm, and 80 vg as runny as water and it works lovely, that's how I like it, empty a 4ml lemo 2 in 30 minuits easy.. and a mini goblin in even less..I trust it will do what the data sheet says but havnt yet encountered a problem.and lipo batteries are high performance and are built for rapid discharge, which means get hot.. Link to comment Share on other sites More sharing options...
