Longtail Posted January 8, 2016 Author Report Posted January 8, 2016 Please excuse the basic question here but I am new to ALL TC more to to DNA and Evolve.Escribe has shown my batteries Watt hours at 15.2, but my box specs tell me that it is 1800mAh. That gives me a Watt hours of 19.something, escribe not available. BUT my batteries show a 4.2V charge on ascribe acress all three cells. Would I be correct in assuming that the 1800mAh for my cells is bogus? or have i got incorrect settings somewhere that I need to fix up? TIA
macz Posted January 8, 2016 Report Posted January 8, 2016 Any info on the mod would be useful or you could run battery analyzer to double confirm your watt hours.
VapingBad Posted January 8, 2016 Report Posted January 8, 2016 Device manager shows the mWh used under Energy at the bottom just note it when fully charged, then when the DNA refuses to fire and the difference divided by a thousand should be a good value for your Wh setting.
Longtail Posted January 8, 2016 Author Report Posted January 8, 2016 Thanks for the answer. The mod is a VTBox 200 by Vape Cige with 3 x 1800 mAh lipo cells. I will look in to the battery analyser to see what I need to do for it. Will also check using the Device manager. way as well. Thanks again.
dwcraig1 Posted January 8, 2016 Report Posted January 8, 2016 Of the posts that I've seen relating to the Lion 1800 mah battery that comes in the Vapecige the actual capacity is around 1250 mah to 1300 mah.
Longtail Posted January 8, 2016 Author Report Posted January 8, 2016 Of the posts that I've seen relating to the Lion 1800 mah battery that comes in the Vapecige the actual capacity is around 1250 mah to 1300 mah. That would definitely explain it then. I have a ticket in to Vape Cige, and although I know they have seen it they haven't yet replied. but these figures sound right to me. Thankyou.
