kevmac Posted January 15, 2016 Author Report Posted January 15, 2016 After my original stock LI-PO died in my VT200 I purchased a direct replacement cell (Hcigar) and a out board Imax B6 charger.The problem I'm having aside from being a 60yr. old techno-boob is I keep getting a "connection break"message I think because I don't know where to plug the wire(1 red and 1 black that has a yellow female connector) that would plug into the board of the mod.the other wire plugs into the 3 cell slot on the charger.The unit has 2 output jacks that accept RCA plugs that come with the unit but none have fittings to fit the battery out line.I'm at a loss and could use some guidance.
digatel Posted January 15, 2016 Report Posted January 15, 2016 Can you take some pics and post them, so we get a better idea what you're dealing with?
VapingBad Posted January 15, 2016 Report Posted January 15, 2016 You normally have to buy or make the lead with these type of chargers as there are so many different types of connector, I think it is an XT30 charge lead you need for that battery to plug into the two 4 mm sockets with the balance plug going into the 4 pin socket white section on the side. Here is a picture (the plugs are not fully inserted to make it clearer for you)
Spirometry Posted January 16, 2016 Report Posted January 16, 2016 http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=92135
kevmac Posted January 17, 2016 Author Report Posted January 17, 2016 Thank you for the help.That seems to make sense.I'll see what I can come up with.As luck would have it I just dropped my tablet and the screen looks like Charlottes'Web. I'm a butterfingers as well as a techno boob so now I have to get another unit so I can continue on the "WEB".Thanks again.
kevmac Posted January 25, 2016 Author Report Posted January 25, 2016 Sorry I took so long to reply but I still am having issues w/ my tablet.I looked at the lead (XT30)on the hobby king site but I need the opposite end .Would you know the name of that lead?I guess I need to try to get the Imax charger going as I'm still having issues w/ the charging on the VT200.I put a new Li-po in it and half the time I lose a third of the full charge as soon as I take 1 pull off it after I remove it from the charge cord.My initial cell that came W/ the unit did the same thing until it finally died.I set the new one on Escribe at 11.1,I thank you for the help you have given me.
