Michael Hancock Posted January 29, 2016 Author Report Posted January 29, 2016 Is the onboard fuse blowing the only built in protection the board has against putting one in backwards?
VapingBad Posted January 29, 2016 Report Posted January 29, 2016 No, it to stop the battery venting or worse in a catastrophic failure as I understand it. If one of 3 cells is reversed the main connections would just see 2/3 voltage and should not fire, but it may damage the battery balance and monitoring circuitry which is not protected by the fuse.
Michael Hancock Posted January 29, 2016 Author Report Posted January 29, 2016 Thanks VB. I'll just throw together a RPP daughter board and mount it to the sled just to prevent any issue that might come up.
