After inserting a fresh set of lg hg2's, the screen won't illuminate. Put a set of hg4's from my rx200 in, same story. Connect it via data cable to my of and the screen reads "warranty service". What might the issue be?
I thought it might as my first did but my battery went bad and I couldn't get rid of the message even with a new battery.. Still try a few others and see if you get the message.. If you do then take the batteries out and try a hard reboot also if you have a multimeter test the batteries are all in balance..
My link in #7 post didn't work out to to correct post, try here:
https://forum.evolvapor.com/topic/67489-topic/?do=findComment&comment=907394
This should link to the entire thread as that was what I was trying for.
http://evolvapor.forumchitchat.com/post?id=7840635
  Fliprrrrr said:
And with no batteries, its registering cell 1 @ .42 v, 2@2.67v, and 3@.25v. That's odd!
Expand
mine says something similar with no batteries and plugged into device monitor. pack voltage is around 3 volts. i think it's just measuring some voltage from being plugged into the usb port. normal.
what does device monitor say with your batts in the device? have you checked the gold plated ground screw located in the battery sled, behind the little foam plug? is it tight/snug, for a battery ground to the board?
  ChunkyButt200 said:
[QUOTE=unExplodeX]i also have this problem and its just today :( tried using new batteries from the shop still doest have any fix? help us please!!!
Expand
individual cell voltages, pack voltages? all in device mon. hard reboot, reflash newest firmware. [/QUOTE]
Expand
individual cell voltages, pack voltages? all in device mon. hard reboot, reflash newest firmware. [/QUOTE] individual cell volatages is reading at 5.80 volts too high. tried hard reboot and the newest firmware iam using is from wismecs website sad :(
