Hi everyone.
I have had a Wismec DNA200 since I think early January, and I have 2 sets of LG HE4's, I have one set that I keep charged so that when the ones in the device are in need of charging, I have another set to swap straight into the device.
I saw on another thread something about dead shorts though, I may have misinterpreted it though, and am worried I should NOT be using this method.
I have moved the ribbon cable to prevent any future issues with that rubbing against the fire button.
If I should be using on board charging, I will start doing that with just 1 set, and keep the others for when these start to have a noticeable drop in capacity.
It would be great if I could continue to use the method I have been though, as I find it simpler to use one of my external chargers, which charges the 18650's faster, and I can use the device straight away with a fresh set.
So, should I not use an external charger and change the batteries, or am I OK carrying on?
I always ensure that the batteries sleeves are intact, and remove them carefully.
Thanks everyone, Conan.
EDIT: I should add, I also like to do this to rotate the batteries after each cycle, I rotate them clockwise so the front cell will become inside right ETC.
VapingBad said:
I replied in the other thread  https://forum.evolvapor.com/topic/66406-topic/?do=findComment&comment=897091
Ok thank you I will check :).
I only made the thread incase my post got lost in the comments, cheers for the fast reply.
