weak battery all the time
r3DJade
 Share
Common ground is fine you just need to make sure the board mounts & 510 ground have good clean & tight contact.  You could add aground wire from the board to the 510 or the case if you want, IMO that is probably best for DIY unless you have a well machined enclosure where the board and the 510 are both screw to the same bit of metal.
 Share
