audiovicious Posted March 13, 2016 Author Report Share Posted March 13, 2016 EDIT: Issue seems to be fixed so far. Removing long, ranty post. Link to comment Share on other sites More sharing options...
VapingBad Posted March 13, 2016 Report Share Posted March 13, 2016 You have had some bad luck there to be sure. Just on the subject of mod res I'm guessing the board mount screws are not tight enough on yours, I would just open it and give them a tweak (don't over tighten them) and you mod res should then read 0.003-0.004. The 510 thread issue is a bigger problem you would need the outer part of the 510 swapped or re-tapped, sorry not much help if you don't have the tools. Link to comment Share on other sites More sharing options...
VapingBad Posted March 13, 2016 Report Share Posted March 13, 2016 These are the case settings I use Link to comment Share on other sites More sharing options...
audiovicious Posted March 13, 2016 Author Report Share Posted March 13, 2016 VapingBad, First off, you have ended hours and hours of me trying to figure out what the problem was. I figured something was loose, but never opened it because I was going to leave that to Evolv, and I didn't know what it was anyway. I was able to open it, tighten the screws, and put your value in, and for the first time since I've had it, it read the resistance right right off the bat. The vape was consistent, and I've had no problems.The 510 threading I'm not going to be sending back over, as I've already smoothed them out and everything screws down by hand now, it was just the initial issue.It looks like everything is working now, thanks so much man.EDIT: What case are those results for? I have the black reference mod. I kept trying to run the case analyzer and it would never go past 'Waiting for steady temperature...' Link to comment Share on other sites More sharing options...
awsum140 Posted March 13, 2016 Report Share Posted March 13, 2016 It takes a while for the temperature to steady, up to an hour is extreme conditions I would guess. Mine took about a half hour and that was a 1590G case. Link to comment Share on other sites More sharing options...
VapingBad Posted March 13, 2016 Report Share Posted March 13, 2016 audiovicious said:VapingBad, First off, you have ended hours and hours of me trying to figure out what the problem was. I figured something was loose, but never opened it because I was going to leave that to Evolv, and I didn't know what it was anyway. I was able to open it, tighten the screws, and put your value in, and for the first time since I've had it, it read the resistance right right off the bat. The vape was consistent, and I've had no problems.The 510 threading I'm not going to be sending back over, as I've already smoothed them out and everything screws down by hand now, it was just the initial issue.It looks like everything is working now, thanks so much man.EDIT: What case are those results for? I have the black reference mod. I kept trying to run the case analyzer and it would never go past 'Waiting for steady temperature...'Glad you got it sorted audiovicious, those results are for a black reference mod. Link to comment Share on other sites More sharing options...
dl12345 Posted March 13, 2016 Report Share Posted March 13, 2016 Fabulous to see some experienced advice make such a difference. Great work VapingBad Link to comment Share on other sites More sharing options...
audiovicious Posted March 14, 2016 Author Report Share Posted March 14, 2016 I should add that tightening those let me go in and use the copper plug and instead of values jumping all over, it just consistently read 0.004 right off the bat. So all of my problems are fixed now. Thanks to Evolv for sticking by it, helping the first time, and then continuing to provide support, and to the forums for the expert advice.I'm beyond pleased with it now. Link to comment Share on other sites More sharing options...
