clank Posted March 12, 2016 Author Report Share Posted March 12, 2016 So I have a DNA 200 with a .25 Uwell Crown coil. Ive had it in there for about a week, however the Vaporshark DNA 200 is still reading coil at .35+ Is this normal ? Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted March 13, 2016 Report Share Posted March 13, 2016 clank said: So I have a DNA 200 with a .25 Uwell Crown coil. Ive had it in there for about a week, however the Vaporshark DNA 200 is still reading coil at .35+ Is this normal ? Expand are you vaping it in power or tc mode? since the crown coils are SS, the ohms will rise from .25 when firing in power mode. that is normal. if you're saying your COLD resistance is .35 then sounds like a connection problem somewhere = coil, coil base, dirty, loose 510 etc. check and see what the mod resistance is set to in escribe. i think VS set it to 0.002? another trick = 'hard reboot' from escribe.do you have other mods to get a resistance reading from the coil in question?i know my .5 crown coils read as .52 in TC. Link to comment Share on other sites More sharing options...
blueridgedog Posted March 13, 2016 Report Share Posted March 13, 2016 And a replacement coil reads? Higher resistance readings are typically related to resistance from the 510, the 510 to atomizer connection and the atomizer. .1 is significant. Link to comment Share on other sites More sharing options...
dl12345 Posted March 13, 2016 Report Share Posted March 13, 2016 While I was still vaping prebuilt coils, I found many were 0.1 ohm over the rated ohms. If you put the atomizer in a different mod or in an ohm reader, does it give a different reading? Link to comment Share on other sites More sharing options...
FiniteWill Posted March 18, 2016 Report Share Posted March 18, 2016 I am having the same issue with my Tuglyfe DNA200. I am using a Cleito with the .4 coil. All my other devices read it as .43, but the cold resistance in escribe reads it as .63, and it is a very disappointing vape. Mod resistance is set to .006, tried a hard reboot as well, that did not solve the issue. Link to comment Share on other sites More sharing options...
