dwaindablane Posted July 23, 2015 Report Posted July 23, 2015 speed4mee said:Is Live Ohm Reading possible?Yes, Under General - Atomizer AnalyzerThis is good for checking your atomizers for possible connection issues, like K4 or Squape-R that are known issues
speed4mee Posted July 23, 2015 Author Report Posted July 23, 2015 Thanks, but i mean Live Ohm Reading on the device.Under Screen - Fields - Default Field 1 there is only Ohms (Standard)
dwaindablane Posted July 23, 2015 Report Posted July 23, 2015 As far as I'm aware kanthal ohms shows live ohms when firing, TC coils only reads your base cold ohms.The only place I know that you can read live ohm on the fly is the atomizer analyzer to check resistance stability.
John Posted July 23, 2015 Report Posted July 23, 2015 Sure is, just set one of your three display fields to it Or plot it in device monitor.
speed4mee Posted July 23, 2015 Author Report Posted July 23, 2015 It's at the Field1 as Default. It shows me only the static value from the start but not the changing resistant value in Temp Control (Live).
dwaindablane Posted July 23, 2015 Report Posted July 23, 2015 Like I said previously and confirmed by John, ohms on the DNA 200 is live when fired in Kanthal mode, but static when using temperature mode and displays only cold temp when you first confirm the ohm of the coil. It's done that way because of refinement mode after you stop vaping, the board refines itself in an attempt to make it more accurate. I personally lock my ohm because I still find certain attys internal ohms drifts and causes either weak/strong sometime burnt vape experience.So that only leaves you the ability to view live ohms in the atomizer analyzer.Why would you want to see live ohms anyway? When Personally vaping I'm not interested in live ohms, nor can I see the screen anyway.If I'm struggling to fault find a atty/coil I have installed, I fire up EScribe software and check the resistance using the atomizer analyzer for stability, There you can normally find loose connections, atty to 510 etc....
John Posted July 23, 2015 Report Posted July 23, 2015 Oh I get what you're trying to do.The problem there is that atomizer analyzer is a special case. The DNA 200 only reads the resistance when it is firing or told to read it, otherwise it would sit there firing the coil all the time, which would waste a good bit amount of power. What atomizer analyzer does is it periodically requests a resistance sample from the DNA, and then displays the results of that sample.That said, there's no reason we can't add device monitor's live ohms (while firing) to the list of fields that could be displayed on the screen, if that would help.
retird Posted July 23, 2015 Report Posted July 23, 2015 You can see live ohm's in the Device Monitor also.... just check "live ohms"and see it change while vaping...
speed4mee Posted July 23, 2015 Author Report Posted July 23, 2015 John said:That said, there's no reason we can't add device monitor's live ohms (while firing) to the list of fields that could be displayed on the screen, if that would help. That would be nice I have that Live Ohm Reading on my SXK Zero Clone 60W on Temp Control.
dajczu Posted April 7, 2016 Report Posted April 7, 2016 And that be very nice for devices with 2S cells. One could check if temp mode is hitting Max voltage(Since dna200 is only step-down). Now the only way to do it is to access Escribe or to setup screen with volts, witch is otherwise useless and you can't disable it without(again) EScribe.
