MIsterious Vaper Posted April 22, 2016 Author Report Share Posted April 22, 2016 i sent my unit up with a 2 cell 18650 i am curently running a 0.29 ohm build and at 100 watts and keep getting ohms too high with any watts over 88.6 watts any info would be helpful Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted April 22, 2016 Report Share Posted April 22, 2016 just putting this out there, the max output when in 2s mode is 6 volts. 100w @ .29 ohms comes to around 5.39v. what you have your mod resistance will come into play as well. in device monitor, with the atty voltage checked, what is the voltage when firing your .29 build at 100w? is it close to the 6v limit? also, here's a thread that might offer some help.https://forum.evolvapor.com/topic/67084-topic/ Link to comment Share on other sites More sharing options...
VapingBad Posted April 22, 2016 Report Share Posted April 22, 2016 It's partly the 6 V output voltage limit with 2 cells, I would expect you could get more power so probably your batteries are struggling or you have a connections issue, you should be able to get 120 W with 0.29 ohm and good batteries and connections.A bit more info https://forum.evolvapor.com/topic/67167-topic/?do=findComment&comment=904624 Is it better with fully charged batteries? Link to comment Share on other sites More sharing options...
MIsterious Vaper Posted April 23, 2016 Author Report Share Posted April 23, 2016 it does this with freshly charged batteries (sam 25r green )i have read thru what i have been able to find on here as for voltage i am firing at 5.43 volts at 100 watts i have also did a case analyst as well as atty to correct for resistance i have just become lost as what else i could do Link to comment Share on other sites More sharing options...
VapingBad Posted April 23, 2016 Report Share Posted April 23, 2016 You could have a look at how the cell voltages are affected in device monitor. Link to comment Share on other sites More sharing options...
