need some input on 2 X 18650
just putting this out there, the max output when in 2s mode is 6 volts. 100w @ .29 ohms comes to around 5.39v. what you have your mod resistance will come into play as well. in device monitor, with the atty voltage checked, what is the voltage when firing your .29 build at 100w? is it close to the 6v limit? also, here's a thread that might offer some help.
https://forum.evolvapor.com/topic/67084-topic/
It's partly the 6 V output voltage limit with 2 cells, I would expect you could get more power so probably your batteries are struggling or you have a connections issue, you should be able to get 120 W with 0.29 ohm and good batteries and connections.
A bit more info https://forum.evolvapor.com/topic/67167-topic/?do=findComment&comment=904624
Is it better with fully charged batteries?
