JamesVally Posted April 27, 2016 Author Report Posted April 27, 2016 When i go to real time monitor my device. It shows verything but the actual temperature of the coil/wire Im using. It just shows a ? This is of a Efusion Lovst Vape DNA 200. Im wondering if the micro usb is messed up somehow. It'd really disappoint me in the chips ability to be used decently. Ive barely had this mod. I tried to contact the manufacturer. But they just told me the model has already been discontinued. This mod sits at home only. Used the griffin tank and Velocity RDA and the Uwell Rafale. Never been dropped, nothing. Im at a loss for what to do?? James
black lace Posted April 27, 2016 Report Posted April 27, 2016 when ever its happened to me its been a bad coil connection, try building another coil..you don't say what wire or ohm, resistance ect
IMoL Posted April 28, 2016 Report Posted April 28, 2016 Does it still show "?" when you press the fire button?All DNA200s show "?" when they are idle - the board is only measuring the resistance change (->temperature) when actually firing.What does it say under the "Cold Ohms" and "Temperature Set" fields?
black lace Posted April 29, 2016 Report Posted April 29, 2016 if your still around lol,,within the first second of fireing the coil needs to increase temperature by 100 degrees to trigger a measurement, are you using stainless per chance?
