ofx66 Posted May 11, 2016 Author Report Posted May 11, 2016 Hi Folks, I am new into the DNA 200 world. I just bought mine putting my cuboid in 2nd place. I whish to get the maximun of my new DNA device, so I plan to run the battery analyzer to get an exact reader of my batteries performance. As told in the subject of this topic, these are 3x18650 Sony VTC 5.I have plan to set the soft cell cutoff limit at 2,6v (I read the battery actually supports it). Is it safe?. I would like to avoid my mod explode in my pocket.Other question I have is on what power to set the test... 40w , which is the default, would be OK, or should I try something like 60w or so?.And the last question for today... does it matter the ohms of the resistance I build to run the test?... I was thinking about a long piese of 3x twisted kanthal wire to be in the subohm range.. (0.5 or so)Thanks for your help!!!Martin from Argentina.
dwcraig1 Posted May 11, 2016 Report Posted May 11, 2016 ofx66 said:Hi Folks, I am new into the DNA 200 world. I just bought mine putting my cuboid in 2nd place. I whish to get the maximun of my new DNA device, so I plan to run the battery analyzer to get an exact reader of my batteries performance. As told in the subject of this topic, these are 3x18650 Sony VTC 5.I have plan to set the soft cell cutoff limit at 2,6v (I read the battery actually supports it). Is it safe?. I would like to avoid my mod explode in my pocket.Other question I have is on what power to set the test... 40w , which is the default, would be OK, or should I try something like 60w or so?.And the last question for today... does it matter the ohms of the resistance I build to run the test?... I was thinking about a long piese of 3x twisted kanthal wire to be in the subohm range.. (0.5 or so)Thanks for your help!!!Martin from Argentina.This post my be of some interest to you with regards to cell cut off:https://forum.evolvapor.com/topic/65604-topic/?do=findComment&comment=886729
ofx66 Posted May 11, 2016 Author Report Posted May 11, 2016 Thanks for your help.. I went trough the thread but there's a qustion I still have.... would it make any difference for the battery analyzer to do it maths if I put a resistance of 0.2ohms or a 0.9ohms?Would the results change ?. Thanks in advance.
dwcraig1 Posted May 11, 2016 Report Posted May 11, 2016 I can only guess at the answer to that, I would imagine there would be a slight change but small. What I see posted as recommended is to run the battery analyzer using the wattage that you mostly vape at.
ofx66 Posted May 12, 2016 Author Report Posted May 12, 2016 Just finished running battery analyzer and here's the results: 21,4Wh @cell cutoff v2,5 with a resistance of 0,8ohms...The batteries are 3x18650 sony VTC5 2600Does it make sense... it's far away from the 28,8Wh the calculator gave me....
dwcraig1 Posted May 12, 2016 Report Posted May 12, 2016 Keep in mind that your not running them down to 2.5 volts, the calculator is a bit more accurate with a Li-polymer as the cut off is higher when rated for Mah21 -22 sounds about right.While you may have set the cut off to 2.5 volts I don't think it will go to that.
ofx66 Posted May 12, 2016 Author Report Posted May 12, 2016 So, I have set back my soft cutoff limit to 2,8... will run the test one more time... , I wish I had those 28,8Wh hehehe
dwcraig1 Posted May 12, 2016 Report Posted May 12, 2016 ofx66 said:So, I have set back my soft cutoff limit to 2,8... will run the test one more time... , I wish I had those 28,8Wh heheheI think it will be the same, just use the 21.4 wh and 2.9 volts cut off.....IMO
VapingBad Posted May 12, 2016 Report Posted May 12, 2016 I have mine set to 21.4 Wh using 3 sets of VTC4s it is spot on with 2 sets, but the newest ones last quite a way past the battery gauge going to zero.
