knightvape Posted May 13, 2016 Author Report Share Posted May 13, 2016 hello I have a problem device boxer dna 133 does not work what is the solution? it is work on the welcome screen and then turns off how can i fix the problem ?? thank you Link to comment Share on other sites More sharing options...
BillW50 Posted May 13, 2016 Report Share Posted May 13, 2016 I would connect it up to EScribe and check in the Device Monitor. Usually it turns on and then off because one of the cells is way off from the other one(s). Link to comment Share on other sites More sharing options...
knightvape Posted May 14, 2016 Author Report Share Posted May 14, 2016 if i connect it up to escribe it turns on After that if i disconnect it turns off and if i push the fire button showing welcome theme and turns off again Link to comment Share on other sites More sharing options...
BillW50 Posted May 14, 2016 Report Share Posted May 14, 2016 Yes I know, but EScribe's Device Monitor will display the cells voltages as well as the pack voltage. It is acting like it isn't happy with one or more of them. So I would like to know what voltages it says they are. If they are fine, maybe it got configured to a 3 cell when it is supposed to be a 2 cell. Link to comment Share on other sites More sharing options...
knightvape Posted May 14, 2016 Author Report Share Posted May 14, 2016 What should you be ? Link to comment Share on other sites More sharing options...
BillW50 Posted May 14, 2016 Report Share Posted May 14, 2016 Cell 1 should be battery 1 voltage and cell 2 is battery 2 voltage (both should read almost if not the same or the DNA200 will turn off) and the pack should be the two added together. Cell 3... well there isn't a battery 3 and normally it should read 0v. But one of mine floats around between 0.50v to 1.10v. I could fix it, but I don't think it is actually affecting or hurting anything. So I have left it alone. Link to comment Share on other sites More sharing options...
