On Friday received my first dna200 mod. Friday I fell in love on Saturday wanting to get a divorce. The problem is after half the day Saturday it went dead on me the last vape had 50% battery life and it only sat for 20 minutes. I plugged it in and it turned on with having 47% battery life still so I unplugged & vaped, set down 15 minutes later took another vape worked great. Here's the issue if it sits for a length of time only way to get the board to turn on is to jump start it through the USB then you can go off the battery. The store I purchased it for had a great deal and now out of stock so all I would get is my $ back and with out that deal wouldn't be able to afford another mod. Please Help.
First off the voltage being displayed in device monitor is what you need look at as what is on the display may not be accurate.
Is the situation with needing jump started with the usb even after charging stops?
For a quick start-up settings l uploaded DjlsbVapes csv files he set for the dx200 as planned on using the board for modding but before I tear the dx200 apart want to make sure the board is good
No, I don't think your board is good. Every one I heard of the same thing happening, it has always been the board. You could try software reset, hardware reset, and force firmware update and stuff. But it doesn't look very hopeful.
