Jez650 Posted July 7, 2016 Author Report Posted July 7, 2016 Hi guys, I have just received a pair of sBody Elfins and seen to have a problem with one of them. When I put an atty on and press fire, the screen reds Ohm's too high. I have tried multiple atty's, all the same. The second mod is working perfectly. Any ideas? I was wondering if it might have a dodgy 510 connection?
Spector NS5 RD Posted July 7, 2016 Report Posted July 7, 2016 are you reaching the 6.2 volt limit of the dna 75? if your coils are .5 and above and you're trying to run them at the upper wattage limit you'll get that message.
Jez650 Posted July 7, 2016 Author Report Posted July 7, 2016 Yeah, but the same Atty works fine on the other identical mod. Tried 3 other Atty's that all work on the other mod, not on this one.
awsum140 Posted July 7, 2016 Report Posted July 7, 2016 If you can short out the 510 on the mod that's giving you problems that should tell the tale. It should read "ohms too low" under a "dead short" condition. To do that safely, attach to eScribe and open the atomizer analyzer. In fact, atomizer analyzer will show you what is going on with the mod even with the atomizer attached, but shorting the 510 will be the "proof of the pudding". From what you're saying I'll guess the mod has a problem.
Jez650 Posted July 7, 2016 Author Report Posted July 7, 2016 Thanks, I think I have a mod problem. I put a velocity RDA on that I wrapped with plenty of Kanthal and got a reading of 0.08 Ohm's on my Ohm reader on and Ran the Atomizer Analyzer, It just came up with a BIG ? and the screen keeps flashing "Ohm's Too High" Bugger!!Anyone know if this is likley to be a board problem or possibly a dodgy wiring solder point or similar?
Verrator Posted January 24, 2018 Report Posted January 24, 2018 I found the problem on mine it was ohm dodging .1 - .3 and occasionally stopped working reading ohms to high! I took it apart and found that the buttons adjusting the wattage were shorting to the board because of a miss placed foam pad, I put some electrical tape on the back and made a form and slapped it right back in and is now working like a charm
