Quick question, I know the 200 is more efficient than the 75 but if it comes down to brass tax and both are running dual batteries, Series in the 200 obviously and parallel in DNA75 which batteries would last longer?
if you run both at, lets say, 75 watts and the same batts, the dna 133 would last longer. by how much, not sure. not whole crazy amount. but would definitely last longer than a parallel batt dna 75. one tidbit of useful info, the watt hours of the two batteries would be equal when using series or parallel configuration, but only when using two of the same battery (same mah, nominal voltage). that's where the board's efficiency comes into play, how well the board uses the batteries.
