combatwombat Posted August 6, 2016 Author Report Posted August 6, 2016 I make claptons with a 430ss 28 awg core and wrap with a 316l ss outer wire. Should I set the tcr in escribe to 430 or 316l? Thanks!
aonoukraine Posted August 6, 2016 Report Posted August 6, 2016 Always set TCR according to the core wire.
James Posted August 6, 2016 Report Posted August 6, 2016 aonoukraine, I am curious, why do you say according to the core wire?I may be extremely tired from coding, but I believe you'd do a custom curve in Steam Engine with the two wires considered to be electrically in parallel.
Rob_H Posted August 6, 2016 Report Posted August 6, 2016 James said: aonoukraine, I am curious, why do you say according to the core wire?I may be extremely tired from coding, but I believe you'd do a custom curve in Steam Engine with the two wires considered to be electrically in parallel. Expand Not trying to steal the thread from OP but I have to ask. Would this work with a Kanthal core and ni200 wrap, making a custom curve or is the two different materials not something the board would deal with.
aonoukraine Posted August 6, 2016 Report Posted August 6, 2016 James said: aonoukraine, I am curious, why do you say according to the core wire?I may be extremely tired from coding, but I believe you'd do a custom curve in Steam Engine with the two wires considered to be electrically in parallel. Expand Yes, you're tired:-) The wire you use as wrap can not significantly affect TCR or even basic resistance because of it's length is approx 15x greater than core wire. Check on steam engine - the TFR curve stays the same when you switch from single ss wire to ss/kanthal clapton. The main rule for claptons is to use temp sensitive wire as core, wrapping doesn't matter.
combatwombat Posted August 6, 2016 Author Report Posted August 6, 2016 Thanks. I forgot about the wire wizard on steam engine.
