turbocad6 Posted August 10, 2016 Author Report Share Posted August 10, 2016 ok I have a question about the dna60 in particular but since there is no dna60 section here yet I figured I'd just ask it here in the dna75 section I'm building a dna60 mod that uses a docking port to charge through a charging dock, and the docking port is directly connected to the usb input connector. my question is, what would/should happen if the pins on this port were inadvertantly shorted while in a pocket, I'm trying to determine how recessed and protected this docking port should be. I've considered using a docking port in the past to directly connect to a lipo for fast charging but decided against it for safety reasons, but here the battery is somewhat isolated from a direct connection to a certain extent, just not sure to what extent and I'm trying to avoid any destructive testing at this point Link to comment Share on other sites More sharing options...
turbocad6 Posted August 12, 2016 Author Report Share Posted August 12, 2016 bump I trying to avoid doing any destructive testing but have no other way of knowing if the + & - input terminals to the usb charging port are protected from shorting in any way Link to comment Share on other sites More sharing options...
BillW50 Posted August 12, 2016 Report Share Posted August 12, 2016 Well do you have a multimeter? If it has zero volts there then shorting the docking port by keys, coins, etc. isn't going to do anything. I find most USB connections are usually dead on the receiving end for the power connections. But it won't be dead if you plug in the USB cable to power though. Link to comment Share on other sites More sharing options...
HolmanGT Posted August 12, 2016 Report Share Posted August 12, 2016 BillW50 said:Well do you have a multimeter? If it has zero volts there then shorting the docking port by keys, coins, etc. isn't going to do anything. I find most USB connections are usually dead on the receiving end for the power connections. But it won't be dead if you plug in the USB cable to power though.Bill,I was going to stay out of this because if the OP does something wrong guess who will be blamed.Anyway, I agree with you and if there was any current available I am sure someone would have blown up a cellphone by now.That said I would short the power pins in the USB with a 1k ohm resistor and then measure the voltage across the resistor.Just using a DMM (digital multi-meter) that typically has an impedance of at least 10 meg ohms you may measure a voltage that is nothing to be concerned about because there is no current of consequence behind it.Using the 1k resistor will eliminate any high impedance voltage that the meter may be able, without the 1k resistor, to read.Using the 1k resistor and a DMM should be more than adequate to determine if the power pins are hot or safe around keys, change and whatever else you may have in your pocket. Link to comment Share on other sites More sharing options...
VapingBad Posted August 12, 2016 Report Share Posted August 12, 2016 You could out a low mA range fuse on it to test turbocad. Link to comment Share on other sites More sharing options...
BillW50 Posted August 12, 2016 Report Share Posted August 12, 2016 HolmanGT said:Bill,I was going to stay out of this because if the OP does something wrong guess who will be blamed.Anyway, I agree with you and if there was any current available I am sure someone would have blown up a cellphone by now.That said I would short the power pins in the USB with a 1k ohm resistor and then measure the voltage across the resistor.Just using a DMM (digital multi-meter) that typically has an impedance of at least 10 meg ohms you may measure a voltage that is nothing to be concerned about because there is no current of consequence behind it.Using the 1k resistor will eliminate any high impedance voltage that the meter may be able, without the 1k resistor, to read.Using the 1k resistor and a DMM should be more than adequate to determine if the power pins are hot or safe around keys, change and whatever else you may have in your pocket.I totally agree with you and VapingBad. Link to comment Share on other sites More sharing options...
HolmanGT Posted August 12, 2016 Report Share Posted August 12, 2016 BillW50 said:I totally agree with you and VapingBad. Link to comment Share on other sites More sharing options...
