Best build/ 28-26g Ni200
JamieanJanie
@JamieanJanie, I use SS and build to around .3-.4 and it's bang on temp. Smooth as glass line in Device monitor. I believe the bigger issue is ensuring that both coils are identical for perfect temp control. I just checked, and under 'coil-wrapping' - setup, there certainly is dual coil. Cheers man
VapingBad said:
0.1 to 0.2 ohm for Ni is a good starting point, but lower is not better as far as I know, it is probably repeated because Ni200 has a very low res and you need to go low to make a reasonable size coil.  I regularly use 0.05 dual setup and wouldn't go lower than that, although it will work.
   I had a light bulb go off my favorite tank to use on my dna is a sigelei elite tank 2 with a ni200 coil at .23 ohms im gonna try to duplicate the build inside of it I guess its a very good vape for me thank you all for the responses
