I was under the impression that with tc the lower your build the more accurate it is. been building four years now Im very well versed on steam engine. just wondering where to start should I just treat it like Kanthal? also theres no dual coil option on steam engines wire wizard whats up with that?
@JamieanJanie, I use SS and build to around .3-.4 and it's bang on temp. Smooth as glass line in Device monitor. I believe the bigger issue is ensuring that both coils are identical for perfect temp control. I just checked, and under 'coil-wrapping' - setup, there certainly is dual coil. Cheers man
0.1 to 0.2 ohm for Ni is a good starting point, but lower is not better as far as I know, it is probably repeated because Ni200 has a very low res and you need to go low to make a reasonable size coil.  I regularly use 0.05 dual setup and wouldn't go lower than that, although it will work.
   I had a light bulb go off my favorite tank to use on my dna is a sigelei elite tank 2 with a ni200 coil at .23 ohms im gonna try to duplicate the build inside of it I guess its a very good vape for me thank you all for the responses
