USB connection stopped working, I've tried on multiple computers with the included USB cable and others, and I can not connect to the PC. Simply not detected. This happened in a hcigar vt75, with 4 days of use. Purchased abroad, because in my country is not yet available for sale.
  • 1 month later...
"USB port was disconnected" is not a box problem as i have seen it happening
on several different devices (I have  a SMY75 and some friends a HCigar75) - it looks more like an evolv/escribe problem.
This issue is quite common with windows 7 and XP while it doesn't usually happen with win 8 and over.
  • 3 weeks later...
i have same problem too, I bought my therion dna 75 last sept 1 2016, then yesterday i finally went to try escribe and still they not found my device but it charge. i tried different usb and usb ports
Be sure the cable has data link and is not just for charging. Paraphrasing:
Using an ohmmeter, check for continuity of the middle two pins between each end of the cable. No continuity or high/"infinite" resistance means the cable is missing data wires and is a "charge only" cable.
