Conanthewarrior Posted September 26, 2016 Author Report Share Posted September 26, 2016 Hi everyone. I has two hotcig DX200s in my collection, the V1 and V2, and had converted the V1 to work with dual 18650's. I had a spare Li-Po for the mod, so thought I might as well use the Li-Po pask as my fiancee liked the device, and I can always go back to the dual 18650 config when I need too. Problem is, in Escribe the battery is reading at cell 1 3.8V, cell 2 0.1V, and cell 3 3.8V too. I have definitely changed the settings to a 3S LiPo config, so it is not that, and this pack did work fine last time trried it. Is it likely the mod is reading the voltage wrong-as i have noticed with the hotcigs the pins need to be slightly bent sometimes to get a true reading, or should I try a recovery charge just in case? I wish I had known the DR200 was coming out as it looks much simpler to swap LiPos in the device. Thanks everyone Conan. Link to comment Share on other sites More sharing options...
retird Posted September 26, 2016 Report Share Posted September 26, 2016 Are the balancing connectors properly wired for 3 cell operation? The V1 was converted for 2 cell operation.... Link to comment Share on other sites More sharing options...
