greenj22 Posted September 30, 2016 Author Report Posted September 30, 2016 Hi there!So I had a few 60's laying around and got restless and threw one in a SS Hana temporarily. It's a truly great little chip. I have been trying to sort out how to integrate 2 amp charging with it. Would one just run off the pin outs 11/12 (splice/add) additional lines over to another USB, then go from that USB to the Satellite USB? A TP4056, for example; Would you go from 11/12 to the TP4056 Battery +/-, then from the in/out of the TP4056 into the Evolv USB Battery +/-, along with the Data Lines striaght from the 60? Thanks in advance!
VapingBad Posted September 30, 2016 Report Posted September 30, 2016 It is in the datasheet, you need to add a resistance in one of the connections, sorry I forget which, if not using the Evolv DNA 60 charge board.
greenj22 Posted September 30, 2016 Author Report Posted September 30, 2016 Thx for the reply! I am using the DNA 60 Charging board....but I think you're talking about the adding of a TP4056 or an Evolv standard 1-amp USB? So is what I was thinking correct, but add in the resistor?
VapingBad Posted September 30, 2016 Report Posted September 30, 2016 I don't have any 60s so can only go by the spec and as I understand it for the 60 charging board it's just straight 1:1 connections, just hooking up to a socket you would add the resistor and using another charge board, if the data lines are not hardwired together and you can get to them measure the resistance on V Detect, probably 0 then add a resistor as needed.
greenj22 Posted October 1, 2016 Author Report Posted October 1, 2016 Yeah. I'm not sure, based off the data sheet and in general. Part of me wants to just think b/c I have the 60 USB, I could just run the 11/12 lines from the board to USB to 60 USB in parallel, then wire the 13-15 straight to the 60 USB, as those are the data lines.....= 2 amps? (Hopefully)
