Tooot Posted March 9, 2016 Author Report Posted March 9, 2016 HiNot sure if this has been done elsewhere here, if so please point me in that direction as this thread will be redundant. I know the answer is really to just run the battery analyzer myself but i was wondering if anyone had some dual 18650 battery curves to share, ideally for 2x Samsung 30q's.
timbomfg Posted March 11, 2016 Report Posted March 11, 2016 I'm afraid that's going to be your answer mostly i think. I managed to find one for the LG HG2s which are close, but tbh i plan on running the analyser to get a more solid value.What do you have set for your Wh and soft cutoff?
zinc Posted March 12, 2016 Report Posted March 12, 2016 http://dna200.de/kurven_akku/i used these... works good although i had to edit the values in the CSV file and delete the last number to get it to import to escribe for some odd reasoni also attached the whole ecig profile for my vt133 that has all the settings (i was also using 30Qs)vt133.ecig
Tooot Posted March 12, 2016 Author Report Posted March 12, 2016 Thank you for the replies.I plan on running the analyzer at some point when i have the time. I am set at 22.2 wh and 3.2v.Ty Zinc i will give that a go
amsalvat Posted March 16, 2016 Report Posted March 16, 2016 I have attached battery profiles for the VT133. One file is for dual Sony VCT4 and Sony VCT5, both in file name. After downloading change the extension ".ecig" to ".csv". Wh setting for VCT4 is 15.01 and 17.77 for VCT5.Vt133SonyVCT5.ecigVt133SonyVCT4.ecig
Burd739 Posted June 29, 2016 Report Posted June 29, 2016 After downloading change the extension ".ecig" to ".csv". Wh setting for VCT4 is 15.01 and 17.77 for VCT5.[/QUOTE] how do I do this ^?
dwcraig1 Posted June 29, 2016 Report Posted June 29, 2016 If your asking how to change it to .CSV here:open file in notepad, select "save as" from drop down menu. Add .CSV to file name. Save as "all files". Load to Escribe and upload to device.
FriscoWeather Posted August 1, 2016 Report Posted August 1, 2016 Would anyone have a csv for the LG HE4?Thanks,Dave
vangelisAEK21 Posted August 4, 2016 Report Posted August 4, 2016 Hello folks,thanks for providing the vtc4 and vtc5 profiles. I've uploaded the vtc5 one but the problem is that when the mod is charging it shows 4.2 Volts for each cell at 89% and keeps going, so I unplugged it.What did i do wrong?I've replaced the Wh to 17.77 and Cutoff to 3.02Thanks in advance
dwcraig1 Posted August 4, 2016 Report Posted August 4, 2016 You can view your charging figures with Escribe in device monitor, the charger built onto the board does a good job of not overcharging the cells over 4.2 volts. I'd say the percentage is not accurate, probably the curve is not quite right as your watt hours are about right.
vangelisAEK21 Posted August 4, 2016 Report Posted August 4, 2016 Thanks for the promt response;it's a very strange behaviour; not sure which one prevails over the other; The Capacity/Cell Soft Cutoff or the CSV file;So if I set any value in the Capacity field which is > 16 Wh then the meter reads lower and tries to charge it more, so like 89% at 4.2. If I set Capacity to 1 then it seems that the CSV takes over and under device monitor the Cell1 tries to exceed 4.2 to 4.21 and device seems not to let it and the meter on the board constantly shows charging at 100% 4.2Volts each.Do you suggest I should run my battery analyzer? i want to avoid it 'cause at home it's not easy to set it upRegards
dwcraig1 Posted August 4, 2016 Report Posted August 4, 2016 As far as I know only the accuracy of the "displayed" battery value will be effected, the charge will be determined by the cell voltage. Note the amperage of charge as they get to 4.2 volts (or 4.1 - maximum recharges )
BillW50 Posted August 4, 2016 Report Posted August 4, 2016 I might be wrong, but from observations, I see two totally different things effecting the battery level (percentage).From waking up (or turned on) it seems to read the battery voltage (and the curve) and use this to set the battery bar.While awake it depends on the watt hours value and/or counter.If I swap batteries while connected to the USB, the battery bar doesn't update (the DNA200 doesn't turn off in this case) with freshly charged batteries until it sleeps and wakes up again.
