nikoskater8 Posted November 28, 2016 Author Report Posted November 28, 2016 hi everyone,i was charging my mod with an 0,50 Amp max wall adapter and the same USB cable i use to connect to escribe, after leaving it there for 1 hour, i reached it to look at what % of charge it had reached and i noticed that it was recharging the mod at 0.18 amp. Since it looked strange (it usually charges at 0.49-0.50 amps) i've unplugged everything and tried to connected to the computer where i've found out that i was no more read by the computer.i've tried to reboot and reset everything on the computer, change the usb cable but nothing worked, so i thought i might recharge completely the battery via ac wall adapter but this time i could not even charge it on the wall adapter.i've tried three different cables and four or five different wall adaptersnow i'm stuck like that..any advices?
Spector NS5 RD Posted November 29, 2016 Report Posted November 29, 2016 does the mod fire niko? if you look inside the USB port do you see any ejuice, dirt ? any broken or bent USB pins inside? other than that, you could contact the vendor you purchased the mod from or open a help ticket with Evolv
nikoskater8 Posted November 29, 2016 Author Report Posted November 29, 2016 it works perfectly except for the USB port!! no juice, nor dirt inside, usb ports seems all normal..i'll contact the vendor since it's been purchased in late august it is still covered with the warranty..i'll keep you updated!
VapingBad Posted November 29, 2016 Report Posted November 29, 2016 If the cells are out of balance and one is almost full it would have to slow, also if the board temp is high it would slow the charge, not sure of the temp limit I think around 125 F, maybe a bit more. You can see the cell voltages in Device Monitor and put the board temp on the charge screen to check if it is either of these reasons.
nikoskater8 Posted November 29, 2016 Author Report Posted November 29, 2016 the box was at room temperature (62-63 F)i can't check the cell voltage in device monitor since the usb port is no more working..i checked on the store, which pointed me to the italian flawless distributor whom i'm dealing with atm!thanks everyone, i'll keep you guys updated
