StirCwazy Posted September 2, 2016 Author Report Posted September 2, 2016 Does anyone know where I can get a discharge profile (CSV) for the basen black 26650? This guy right here.
Wayneo Posted September 2, 2016 Report Posted September 2, 2016 You can always create your own profile from with Escribe instead of waiting. I don't have any 26650's.Cheers.
jka Posted September 13, 2016 Report Posted September 13, 2016 Hi there;New user to Escribe but never the less: I found an discharge profile for the black Basen 26650.Enjoy !jkaBasen26650.csv
jka Posted September 14, 2016 Report Posted September 14, 2016 My pleasure !Actually I have the same battery for my Hotcig DX75.....so I was searching for the same CSV.
thewarm Posted December 6, 2016 Report Posted December 6, 2016 I use these in my new VapeDroid C1D2. Waiting to be able to download the CSV file and try this out.Thanks
Wayneo Posted December 6, 2016 Report Posted December 6, 2016 You folks might want to check out the true ratings for many batteries from the highly regarded and trusted mooch before buying any vaping batteries at all. Yours is not on his list, so just for future reference.https://www.e-cigarette-forum.com/forum/blog-entry/list-of-battery-tests.7436/Cheers and hope you're enjoying your mods.
jka Posted December 7, 2016 Report Posted December 7, 2016 Hi Wayneo;Thank you for the info. Actually it is listed:Top Performers (in alphabetical order)AWT Yellow 75A 4500mAhBasen Black 4500mAhBrillipower Green 80A 4500mAhEfest Green 20A 4200mAhEfest Purple 40A 4200mAh (Not recommended yet due to the one dud cell)MNKE Orange 35A 3500mAh (NOT RECOMMENDED, due to all the fakes being sold)MXJO Yellow 35A 3500mAhNOTE: I'm getting another four Efest Purple 4200mAh cells to test. If all four do well I'll add that battery to the recommended list (except for Stout owners, might be too long). Continued in the following posts due to ECF's limit of 10 images per post... Mooch, Jan 20, 2016 Basen Black 4500mAh This cell only has an exaggerated 60A pulse rating on the wrap with no continuous rating to be found on the Basen web site. When pulsed at 50A the voltage started at under 3.0V and soon dropped off from there. This is clearly not a 60A pulse cell. But it was one of the top five 26650's I tested and I gave it a 25A continuous (estimated) rating. Its length of 66.4mm means it should fit in the VF Stout without problems Mooch, Jan 20, 2016 BRJKA
K.Svendsen Posted December 23, 2016 Report Posted December 23, 2016 I just got my VapeDroid DNA75 mod yesterday, so im totally green.I use iJoy 26650 4200mah, but can't find a .csv file for that battery.Is the discharge profile a finetune of the batterybar indicator in display?or does it discharge different with different curves? I was thinking aboutusing the " Basen26650.csv" OR just make a curve saying:At the Left: 4.19 volt - At the Right: 3.21 volt or will thatprofile curve dammage the battery in the long run?Regards, Kim
dwcraig1 Posted December 23, 2016 Report Posted December 23, 2016 The curve only makes the battery gauge more accurate, it doesn't change battery performance
K.Svendsen Posted December 23, 2016 Report Posted December 23, 2016 Thank you so much dwcraig1 Then i dare edit, and make my own simple profile curve.
Mustafa Posted October 24, 2017 Report Posted October 24, 2017 Can any one give a discharge profile for AWT 4500mah 26650 battery please
giz_60 Posted October 24, 2017 Report Posted October 24, 2017 On 12/23/2016 at 9:38 AM, K.Svendsen said: I just got my VapeDroid DNA75 mod yesterday, so im totally green. I use iJoy 26650 4200mah, but can't find a .csv file for that battery. Is the discharge profile a finetune of the batterybar indicator in display? or does it discharge different with different curves? I was thinking about using the " Basen26650.csv" OR just make a curve saying: At the Left: 4.19 volt - At the Right: 3.21 volt or will that profile curve dammage the battery in the long run? Regards, Kim IJoy_26650_4200 mah_14.57 Wh.csv
K.Svendsen Posted October 24, 2017 Report Posted October 24, 2017 Thank you giz_60 much appreciated...
