Alvon Posted December 26, 2016 Author Report Share Posted December 26, 2016 Hi Guys, I just bought brand new Therion DNA133, but when i plug the 2 (AWT RED 3000mah 40a) 18650 battery (Fully charge) the battery indicator on screen is showing that is empty. but the mod it self is fully functional.Can you guys help me to solve this issue? because i think that is only problem on the EScribe setting. below is the screenshot of my current setting. Thank you Link to comment Share on other sites More sharing options...
Spector NS5 RD Posted December 27, 2016 Report Share Posted December 27, 2016 welcome Alvon. your cells are imbalanced. cell 1- 4.10 / cell 2- 3.50. i would double check their voltage, individually, with a DMM or standalone charger or you can swap the cells around, in the therion, and see if the corresponding voltages follow the cells in device monitor and report back. if the cells are in fact imbalanced from each other, you need to charge them separately, out of the therion. if the cells are not imbalanced, something is getting in the way of the DNA board reading the correct cell voltage. could be a poor/dirty battery contact. Link to comment Share on other sites More sharing options...
Alvon Posted December 27, 2016 Author Report Share Posted December 27, 2016 Hi Chunky,Thank you for your responses, i will note that.But now the problem is solved after i am fully re-charge my battery overnight. and i will re-check on device monitor.Thank you. Link to comment Share on other sites More sharing options...
joseph1203 Posted December 27, 2016 Report Share Posted December 27, 2016 Alvon said: Hi Guys, I just bought brand new Therion DNA133, but when i plug the 2 (AWT RED 3000mah 40a) 18650 battery (Fully charge) the battery indicator on screen is showing that is empty. but the mod it self is fully functional.Can you guys help me to solve this issue? because i think that is only problem on the EScribe setting. below is the screenshot of my current setting. Thank you Expand do you have curve in awt? kindly share because my spare battery is awt same as to you. is it correct if Mah is 3000? Link to comment Share on other sites More sharing options...
Wayneo Posted December 27, 2016 Report Share Posted December 27, 2016 ... this is a confusingly labeled 3000mAh battery with only a 20A continuous discharge rating (CDR) - from the master. And NOT on his recommended Battery List 9/17/2016 Link to comment Share on other sites More sharing options...
joseph1203 Posted December 27, 2016 Report Share Posted December 27, 2016 Wayneo said: ... this is a confusingly labeled 3000mAh battery with only a 20A continuous discharge rating (CDR) - from the master. And NOT on his recommended Battery List 9/17/2016 Expand when was the battery vheck appeared on you screen in what battery % you can consune all the battery life down to its 5%? if the said cut off reaches Link to comment Share on other sites More sharing options...
Wayneo Posted December 28, 2016 Report Share Posted December 28, 2016 joseph1203 said: when was the battery vheck appeared on you screen in what battery % you can consune all the battery life down to its 5%? if the said cut off reaches Expand Answered in the other thread. Link to comment Share on other sites More sharing options...
JewelHanda Posted December 9, 2019 Report Share Posted December 9, 2019 Hi.. to extend the battery life, the unite uses a small current to charge. Standatd charging hours is 4-6 hours. For some battery may be longer. The battery indicator is indicating the current battery voltage. The actual charging circuit checkes charging current to determain if the battery is full. Do not warry the overchage, the circuit will take care it. Link to comment Share on other sites More sharing options...
