Hi guys, not sure if this has been covered before here cause I can't seem to find it. Just put a fresh battery in my Skar75, hooked up to the computer & the LED came on green...normal since it is a fresh battery with full charge. Was vaping while working on the computer & awhile later, noticed that the LED was still green. Opened device monitor in Escribe & the battery level was down to about 95%. Vaped until I got the battery level down to about 81% & the LED never switched to flashing red to indicate a charging condition. Watched device monitor...could see that the USB was in fact charging the battery. Is this something normal with the 75 board. Can't compare it to the 250 due to no LED.
hysteresis between the charging chip and LED function.  all of the DNA 75 do this. you have to unplug, then plug back in the USB cable. it will then turn red (or whatever color you have set for "charging"). normal operation for the board.
And just a further note..... while charging with the red led showing as it reaches 100% the charge rate decreases and you may think it will never turn green..... be patient... :)
Thanks retird...I had noticed the red showing at 100% before but yes it does eventually turn green. This was the first time I had actually vaped while connected to a USB, so wasn't sure about the green turning to red...now I knows...Thanks again!!
