Bigpunisher Posted January 15, 2017 Author Report Share Posted January 15, 2017 Finally took the leap to a DNA200 device!I got home, plugged it into Escribe and attempted to update the firmware only to be presented with this error. Initial message I'm given is:[CODE]"Unhandled exception has occurred in your application, if you click continue, the application will ignore this error and attempt to continue. If you click Quit the application will close immediately. Exception of type 'J.dc' was thrown, [/CODE]I then get 3 options, Details (Details shown below) Continue and Quit, Continue shuts my device off and quit closes Escribe with nothing happening. [CODE]See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************J.dc: Exception of type 'J.dc' was thrown. at W.gc.mp(IWin32Window , kb ) at DimensionEngineering.Common.Platform.Windows.WindowsPlatformHelper.ShowProgressBar(kb callback) at r.aL.A(dp , Object , Boolean& , Boolean ) at r.aL.bmw.JA() at r.aL.J(eD , bmo , Boolean , Boolean& , Boolean ) at r.aL.u(Func`1 , Boolean& , Boolean , Boolean ) at r.aL.dd() at e.nJ.GP.Tx() at e.nJ.GP.Gm.v(Object , EventArgs ) at W.gU.m(Object , LinkLabelLinkClickedEventArgs ) at System.Windows.Forms.LinkLabel.OnLinkClicked(LinkLabelLinkClickedEventArgs e) at System.Windows.Forms.LinkLabel.OnMouseUp(MouseEventArgs e) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.Label.WndProc(Message& m) at System.Windows.Forms.LinkLabel.WndProc(Message& msg) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)************** Loaded Assemblies **************mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll----------------------------------------DEScribe Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/EScribe.exe----------------------------------------System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll----------------------------------------System Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll----------------------------------------System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll----------------------------------------DimensionEngineering.Common.Windows Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.Windows.DLL----------------------------------------DimensionEngineering.PluginApi Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.PluginApi.DLL----------------------------------------DimensionEngineering Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.DLL----------------------------------------DimensionEngineering.Common Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DimensionEngineering.Common.DLL----------------------------------------DEScribe.Branding Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.DLL----------------------------------------System.Xml.Linq Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll----------------------------------------System.Core Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll----------------------------------------System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll----------------------------------------DEScribe.Core Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.DLL----------------------------------------n Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Branding.dll----------------------------------------DEScribe.UI Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.UI.DLL----------------------------------------DEScribe.PluginApi Assembly Version: 1.4.0.0 Win32 Version: 1.4.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.PluginApi.DLL----------------------------------------Mono.Addins Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/Mono.Addins.DLL----------------------------------------IllusoryStudios.OpenSsl Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/IllusoryStudios.OpenSsl.DLL----------------------------------------Evolv.DNA Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/Evolv.DNA.DLL----------------------------------------System.Security Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll----------------------------------------System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.6.1586.0 built by: NETFXREL2 CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll----------------------------------------SecondLanguage Assembly Version: 1.0.3.1 Win32 Version: 1.0.3.1 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/SecondLanguage.DLL----------------------------------------ICSharpCode.SharpZipLib Assembly Version: 0.86.0.518 Win32 Version: 0.86.0.518 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/ICSharpCode.SharpZipLib.DLL----------------------------------------EquationParser Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/EquationParser.DLL----------------------------------------IllusoryStudios.Math Assembly Version: 1.1.0.0 Win32 Version: 1.1.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/IllusoryStudios.Math.DLL----------------------------------------r Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DEScribe.Core.dll----------------------------------------NBit Assembly Version: 1.2.1.0 Win32 Version: 1.2.1.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/NBit.DLL----------------------------------------DeviceConnectivity Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DeviceConnectivity.DLL----------------------------------------CookComputing.XmlRpcV2 Assembly Version: 3.0.0.0 Win32 Version: 3.0.0.270 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/CookComputing.XmlRpcV2.DLL----------------------------------------XmlRpcProxy7b1753d4-7f85-4543-8ca5-8c8cf4a760e0 Assembly Version: 0.0.0.0 Win32 Version: 3.0.0.270 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/CookComputing.XmlRpcV2.dll----------------------------------------DeviceMonitor.Core Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DeviceMonitor.Core.DLL----------------------------------------HidSharp Assembly Version: 1.10.0.0 Win32 Version: 1.10.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/HidSharp.DLL----------------------------------------T Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DeviceConnectivity.dll----------------------------------------SaberUpload Assembly Version: 1.0.0.0 Win32 Version: 1.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/SaberUpload.DLL----------------------------------------t Assembly Version: 0.0.0.0 Win32 Version: 0.0.0.0 CodeBase: file:///C:/Users/James/AppData/Roaming/Evolv/EScribe%20Suite/DeviceMonitor.Core.dll----------------------------------------************** JIT Debugging **************To enable just-in-time (JIT) debugging, the .config file for thisapplication or computer (machine.config) must have thejitDebugging value set in the system.windows.forms section.The application must also be compiled with debuggingenabled.For example:<configuration> <system.windows.forms jitDebugging="true" /></configuration>When JIT debugging is enabled, any unhandled exceptionwill be sent to the JIT debugger registered on the computerrather than be handled by this dialog box.[/CODE]Please give me any help you can, I'm desperate as my device isn't acting normal! Link to comment Share on other sites More sharing options...
James Posted January 16, 2017 Report Share Posted January 16, 2017 What operating system, and what version of EScribe are you running (1.2 SP5.1?)?Does it work if you manually use Tools->Update Firmware? Link to comment Share on other sites More sharing options...
Bigpunisher Posted January 18, 2017 Author Report Share Posted January 18, 2017 James said:What operating system, and what version of EScribe are you running (1.2 SP5.1?)?Does it work if you manually use Tools->Update Firmware?Hi James, thanks for the reply.Using Escribe version 1.2 SP5.2Still getting an error, going to tools > apply service pack > DNA 200 folder > 1_2_SP5.SW.Service is the pack I apply, it's now not turning on regardless of batteries or plugged into USB... Link to comment Share on other sites More sharing options...
VapingBad Posted January 18, 2017 Report Share Posted January 18, 2017 Bigpunisher said:Hi James, thanks for the reply.Using Escribe version 1.2 SP5.2Still getting an error, going to tools > apply service pack > DNA 200 folder > 1_2_SP5.SW.Service is the pack I apply, it's now not turning on regardless of batteries or plugged into USB... What version of Windows: Vista, 7, 8 or 10 and 32 or 64 bit? Link to comment Share on other sites More sharing options...
Bigpunisher Posted January 18, 2017 Author Report Share Posted January 18, 2017 VapingBad said:What version of Windows: Vista, 7, 8 or 10 and 32 or 64 bit?Hi, Windows 10 64bit. Link to comment Share on other sites More sharing options...
