I had a DNA 200 built in a Hammond box dual 18650 in series. The question I have is when I go to use it it will only ramp up to 50w at max, even when adjusted higher. Anyone ran into this? Any help is appreciated! Using lg hg2 batteries.
Here's an example of where I would start looking.
In EScribe/Device Monitor tick the two cells and not what the voltage sag is. My batteries in this example were 3.68 unloaded and when fired drop to near the soft cell cutoff. Had they dropped below the set soft cell cut off the power would have dropped.
Here's my example:
S
o take a look at yours and let us know, post it if possible.
The only setting on that page that can have anything to do with your problem is set correctly to 133 watts.
We need to see it firing in Device Monitor with the two cell ticked. Use the stop button in the right lower corner once you get it then move your mouse over the sagged voltage points to show the voltages (if not showing)
Looks like one battery is hitting your 'cell soft cutoff' setting. Are you seeing a 'check battery' message on your screen? I too run 2 LG HG2's & have my cell soft cutoff set at 2.8
No check battery but the battery bar did flash once. And my cut off is set to 3.09.
I'm almost to the point of thinking my batteries are the issue. Thinking of picking up a brand new set today. Just to see if that's what it is. BC good lg's should support way more then 50w.
giz_60 said:
Oh yeah...they changed the message to a flashing battery symbol...lower your cell soft cutoff to 2.8 or 2.9 & give it a try...
I tried that and it said check battery as soon as I hit the button. Lowest I could take it was 3.00v
dwcraig1 said:
I'm expecting this to be another situation where the battery contacts are not making good connection to the cells.
Idk. Wouldn't think so being the mod was just finished being built yesterday.....Or at least I hope it isn't.
OK, for sure power isn't getting from the cells to the board. Could be poor cells (probably not), bad solder joint on B+ or B- or at battery sled(lo or at battery sled. But most likely battery contacts to cell, make sure they have as square contact as possible and tight against cell.
Alright I appreciate all the help from everyone. Gonna try new cells and if that dosnt work back to builder.
retird said:
Any chance of getting a picture of the internals of the Hammond box?  So since new yesterday it hasn't ever worked right?
I can later on. It's a good freind that built it. Just gonna get back with him and see what's going on. Because I've never had any problems with his mods.
