Place to share Battery Test Results.
mikepetro
I have created a place to share our Battery Analyzer Results with each other. I would like to ask everybody to help each other out and please contribute!
Note, please only post actual Escribe Battery Analyzer results, not advertised specs.
Results can be viewed here, the battery results are on the right hand tab visible at the bottom.
https://goo.gl/b33IPB
Form to enter a Battery Test Result:
https://goo.gl/IP9iSA
Form to enter a DNA200 DIY Resource:
https://goo.gl/Qmr6Is
mikepetro said:
Cool, Will do.
Can you give feedback on the result difference? I am assuming lower loads yielded better capacity????
Exactly. I will post my results, but to be fair to Tunigy I need to do all tests with the same conditions. One test I did with 100% battery with no trickle charging the other I did as soon as it hit 100% but noticed as i unplugged it it was still charging. I will do a third test at the actual Ohms I vape at just for a comparison. ;)
I really dont think the "load" or "wattage" matters. I think it is as simple as "energy in = energy out" because Battery Analyzer does all it can to extract every watt-hour above 3.09v regardless of load.
I ran 4 tests on a well seasoned Evolv Beta Mod, two with a 0.51 ohm load, and two with a 0.26 ohm load. I ran one test at 40watts, and the other at 174watts.
The results were all within 0.07 watt-hours of each other, ie 9.788wh to 9.853wh. No consistency or conclusion from the low and high.
Tests were ran on this:
There are 17 Battery Results posted so far, the battery results are on the right hand tab visible at the bottom.
Please support this effort!
  • 1 month later...
I see that now.  Looks like when the sag hits the cutoff it's stopping the fire which is expected.
I am testing several batteries... I think all are already on the list but I have multiple of each and I'm doing breaking them in first the proper way etc.
Looks like some folks doing tests on 18650's are using 2.5v cutoff.  I wonder if that would skew results vs/on lipos?  It might be a useful field to add to the list if nothing else.
PS: That's an insane block of aluminum :D  Have you checked temps on the resistors?
  • 4 weeks later...
Hello every one I am Planning on a my first Regulated build and want to try and steer away from the normal 18650 and 26650s and have been doing some research on different LiPO batters 3S 11.1V and have come across some and i understand the math with every thing but i would like to hear from the community on what they think if High C-Discharge is better with a higher mAh looking for long life and here is a sight i just came across that I think if the money was present for some of the high mAh and also high C-discharge which in turn means more amps http://www.maxamps.com If any one has used battery from here please let all of us know your experience with the company and with the battery or just let me know if its worth the money out Thank you and have a great day/night.
       -----Kagaen
  • 9 months later...
       -----Kagaen
You just put a link to YOUR STORE! Anyine got cvs for 3 vtc4?
  • 3 months later...
