mikepetro Posted October 24, 2015 Author Report Share Posted October 24, 2015 I have created a place to share our Battery Analyzer Results with each other. I would like to ask everybody to help each other out and please contribute!Note, please only post actual Escribe Battery Analyzer results, not advertised specs.Results can be viewed here, the battery results are on the right hand tab visible at the bottom.https://goo.gl/b33IPBForm to enter a Battery Test Result:https://goo.gl/IP9iSAForm to enter a DNA200 DIY Resource:https://goo.gl/Qmr6Is Link to comment Share on other sites More sharing options...
retird Posted October 24, 2015 Report Share Posted October 24, 2015 How about adding "true" case analyzer data to your collection also for all the devices out in the wild? Link to comment Share on other sites More sharing options...
mikepetro Posted October 24, 2015 Author Report Share Posted October 24, 2015 The focus of this resource is DIY stuff, not really so much commercial mods.I will consider it though. Link to comment Share on other sites More sharing options...
scoopy Posted October 26, 2015 Report Share Posted October 26, 2015 I don't see any battery stats or curves at al?? Link to comment Share on other sites More sharing options...
mikepetro Posted October 26, 2015 Author Report Share Posted October 26, 2015 Look at the bottom and select the the "Battery Results" tab Link to comment Share on other sites More sharing options...
mikepetro Posted October 26, 2015 Author Report Share Posted October 26, 2015 Link to comment Share on other sites More sharing options...
mikepetro Posted October 28, 2015 Author Report Share Posted October 28, 2015 Bump, please contribute!It will help all of us make educated decisions on which battery to buy. Link to comment Share on other sites More sharing options...
mikepetro Posted November 2, 2015 Author Report Share Posted November 2, 2015 Bump Link to comment Share on other sites More sharing options...
Jordan4690 Posted November 2, 2015 Report Share Posted November 2, 2015 How do I go about running the test? Do I just put a coil and no wick I don't get it Link to comment Share on other sites More sharing options...
mikepetro Posted November 2, 2015 Author Report Share Posted November 2, 2015 Check out this thread for some examples:https://forum.evolvapor.com/topic/65611-topic/ Link to comment Share on other sites More sharing options...
TheRedBaron Posted November 11, 2015 Report Share Posted November 11, 2015 Mike, I love what you're doing but can I make a suggestion? Add a column for the Ohms load it was tested under. I have tested my battery with different Ohms load and got totally different results. Link to comment Share on other sites More sharing options...
mikepetro Posted November 11, 2015 Author Report Share Posted November 11, 2015 Cool, Will do.Can you give feedback on the result difference? I am assuming lower loads yielded better capacity???? Link to comment Share on other sites More sharing options...
mikepetro Posted November 11, 2015 Author Report Share Posted November 11, 2015 Done, Added both "Test Load" and "Test Wattage". Link to comment Share on other sites More sharing options...
awsum140 Posted November 11, 2015 Report Share Posted November 11, 2015 I was going to comment that reasonable loads would produce more realistic results. The chip will run up to 200 watts, but most people don't use that much power in "real", day to day, vaping so a lower, more "real" load might give better, real life, results. Link to comment Share on other sites More sharing options...
TheRedBaron Posted November 11, 2015 Report Share Posted November 11, 2015 mikepetro said:Cool, Will do.Can you give feedback on the result difference? I am assuming lower loads yielded better capacity???? Exactly. I will post my results, but to be fair to Tunigy I need to do all tests with the same conditions. One test I did with 100% battery with no trickle charging the other I did as soon as it hit 100% but noticed as i unplugged it it was still charging. I will do a third test at the actual Ohms I vape at just for a comparison. Link to comment Share on other sites More sharing options...
mikepetro Posted November 22, 2015 Author Report Share Posted November 22, 2015 I really dont think the "load" or "wattage" matters. I think it is as simple as "energy in = energy out" because Battery Analyzer does all it can to extract every watt-hour above 3.09v regardless of load.I ran 4 tests on a well seasoned Evolv Beta Mod, two with a 0.51 ohm load, and two with a 0.26 ohm load. I ran one test at 40watts, and the other at 174watts.The results were all within 0.07 watt-hours of each other, ie 9.788wh to 9.853wh. No consistency or conclusion from the low and high.Tests were ran on this:There are 17 Battery Results posted so far, the battery results are on the right hand tab visible at the bottom.https://goo.gl/b33IPBForm to enter a Battery Test Result:https://goo.gl/IP9iSAPlease support this effort! Link to comment Share on other sites More sharing options...
mikepetro Posted December 30, 2015 Author Report Share Posted December 30, 2015 Bumping this up. There are 23 Battery Results posted so far, the battery results are on the right hand tab visible at the bottom.https://goo.gl/b33IPBForm to enter a Battery Test Result:https://goo.gl/IP9iSA Link to comment Share on other sites More sharing options...
justchil Posted January 5, 2016 Report Share Posted January 5, 2016 Are you guys firing until the soft cutoff hits or what? Link to comment Share on other sites More sharing options...
mikepetro Posted January 5, 2016 Author Report Share Posted January 5, 2016 justchil said:Are you guys firing until the soft cutoff hits or what?Battery Analyzer does the firing, and yes, that is basically what it does. Link to comment Share on other sites More sharing options...
justchil Posted January 5, 2016 Report Share Posted January 5, 2016 I see that now. Looks like when the sag hits the cutoff it's stopping the fire which is expected.I am testing several batteries... I think all are already on the list but I have multiple of each and I'm doing breaking them in first the proper way etc.Looks like some folks doing tests on 18650's are using 2.5v cutoff. I wonder if that would skew results vs/on lipos? It might be a useful field to add to the list if nothing else.PS: That's an insane block of aluminum Have you checked temps on the resistors? Link to comment Share on other sites More sharing options...
justchil Posted January 6, 2016 Report Share Posted January 6, 2016 I'm also curious which enclosure "Bob" was able to get a MA 2800mAh into I will be posting results tonight. I ran 5x tests per battery type. I did see more mAh firing at a lower wattage with a 2.5v cutoff but not at 100w/2.5v. Link to comment Share on other sites More sharing options...
Kagaen Posted February 3, 2016 Report Share Posted February 3, 2016 Hello every one I am Planning on a my first Regulated build and want to try and steer away from the normal 18650 and 26650s and have been doing some research on different LiPO batters 3S 11.1V and have come across some and i understand the math with every thing but i would like to hear from the community on what they think if High C-Discharge is better with a higher mAh looking for long life and here is a sight i just came across that I think if the money was present for some of the high mAh and also high C-discharge which in turn means more amps http://www.maxamps.com If any one has used battery from here please let all of us know your experience with the company and with the battery or just let me know if its worth the money out Thank you and have a great day/night. -----Kagaen Link to comment Share on other sites More sharing options...
Vaperkarloz Posted November 23, 2016 Report Share Posted November 23, 2016 Kagaen said:Hello every one I am Planning on a my first Regulated build and want to try and steer away from the normal 18650 and 26650s and have been doing some research on different LiPO batters 3S 11.1V and have come across some and i understand the math with every thing but i would like to hear from the community on what they think if High C-Discharge is better with a higher mAh looking for long life and here is a sight i just came across that I think if the money was present for some of the high mAh and also high C-discharge which in turn means more amps http://www.maxamps.com If any one has used battery from here please let all of us know your experience with the company and with the battery or just let me know if its worth the money out Thank you and have a great day/night. -----Kagaen You just put a link to YOUR STORE! Anyine got cvs for 3 vtc4? Link to comment Share on other sites More sharing options...
DonMicha Posted March 9, 2017 Report Share Posted March 9, 2017 thanks Link to comment Share on other sites More sharing options...
badrudin Posted March 11, 2017 Report Share Posted March 11, 2017 I want CVS battery test result AWT 3000MAH 35A Link to comment Share on other sites More sharing options...
