Darth vapes Posted April 23, 2017 Author Report Posted April 23, 2017 on my therion i can adjust the wattage in tc...then when i vape it shows in the left plane which is correct...but with my new triade i do the same thing but the wattage changes in auto mode...cant seem to set the watts to 75 and stay there..if i ajust the temp lower then the wattage will go lower as well...if i up the temp then the wattage will go up as well...so its auto ajusting...Why?..and how can i stop this from happening?
giz_60 Posted April 23, 2017 Report Posted April 23, 2017 In TC mode, the device is only going to use the wattage necessary to achieve the temp you have it set for...so, lower desired temp, less wattage...higher desired temp, higher wattage...if you have the material profile set for Temperature Dominant & on the 'Screen' tab in Escribe, if you set the field on the left to 'Temperature (standard)', then it will show the wattage you have it set for, but when firing, it will show the wattage actually being used to achieve the desired temp...after firing, it will go back to showing the wattage you have it set for...if you have the field to the left set for 'Last Power' , then you are going to see the actual wattage that was used to achieve the desired temp...hope this made sense...
Darth vapes Posted April 23, 2017 Author Report Posted April 23, 2017 Are i found the problem!....seems in screen mode it was set to last power instead of (temp) which is the standard for the middle screen!...now it shows watts that i have set...But why does it not show temp?...should it be watts on the right plane..(the main screen)..and temp in the small middle left plane?....i mean if i picked temp which i did then why does it show wattage?
giz_60 Posted April 23, 2017 Report Posted April 23, 2017 If you look at the material profile, 'General Tab', that you are using, you probably have that profile set for Temperature Dominant. That will show the temp on the right side of the screen & will automatically change from temp on the left to wattage...if you uncheck the temperature dominant in the profile, you will see the wattage on the right & the temp on the left
Darth vapes Posted April 24, 2017 Author Report Posted April 24, 2017 Yes i did..lol...did not see that...so if i don't check that it will stay wattage Dominant
Darth vapes Posted April 24, 2017 Author Report Posted April 24, 2017 Also finding the Triade hitting harder at 70w than the Therion at the same wattage...that will be the third battery helping out i guess.
Wayneo Posted April 24, 2017 Report Posted April 24, 2017 Darth vapes said:Also finding the Triade hitting harder at 70w than the Therion at the same wattage...that will be the third battery helping out i guess.That could be because one or both mods were not tuned by LV (mod resistance an thermals), or your therion is bumping into the 6V Output Voltage limit.
Darth vapes Posted April 24, 2017 Author Report Posted April 24, 2017 Mod resistance are both set to 0.004 from factory
giz_60 Posted April 24, 2017 Report Posted April 24, 2017 Darth vapes said:Yes i did..lol...did not see that...so if i don't check that it will stay wattage DominantYes, and you will see the temp on the field to the left, instead of wattage
