Therion dna 166
Hey guys. Just got myself a therion dna 166 and gone through escribe and working beautifully. My problem is, in wattage mode. When I fire the mod it jumps up the watts before it gets to my desired wattage. E.g. I've got the cleito 120 set to 75w when I press the fire button it goes from 0w - 45w then to 75wbbis this normal? Just wanting to check. Cheers! ??
Like when you floor the gas pedal in a car and 'all at once' reach your desired speed? Mine takes ~.38 seconds to hit 133 watts.
Perfectly normal. The display is showing you 'live' values.
Akesvapes said:
It is normal yes.
Only in Temp mode can you change this, unfortunately not in power mode.
I am hoping Evolv changes this with the next firmware upgrade.
o.O. You can't change this in any mode. There is NO BUG, and nothing to change.  o.O
