Everything posted by RicketyPumpkin
@aMirS would you mind posting the links for these cases? that's easily the coolest accessory I've ever seen for a modern day full size mod. Are those tiny displays actually showing charging a battery at 1a? or are the just V displays? Thanks in advance
If I understand you correctly, you want to restore the firm "click" you had when you originally bought your 250C? What mod is it first off? Also, how deep are you looking to get into this? There is a membrane between the physical buttons you touch & the actual hardware buttons on the 250C, I can't speak to every manufacturer, but for Lost Vape, this is the case. Both the exterior buttons and membrane can be replaced on mine for example, since they both have removable rubber components. If. The boards clickiness is spongy now, you could solder new buttons but you'd have to source them and be confident in your soldering. Those options aside, you're "most complete fix"6 option would be to just spend the $80 USD and replace the entire 250C, board, screen, buttons, everything. If your buttons are starting to feel mushy, I can't imagine that device is very new so I would think the screen and a few other things wouldn't mind being replaced either 😅 Depending on how long you've had the mod, it's likely the board side buttons, as silicone /rubber can stay firm for years and years if taken care of but the board buttons work off the same principle as a membrane, but are less forgiving than the latter due to the material being an alloy and the water resistance built-in. A donor board would be great for you, I have a few and haven't regretted it once.
Need help with error, Curve must be strictly increasing
RicketyPumpkin replied to Tyear Lekatompessy's topic in DNA 250 Color
Wrong post, I hate windows 11 so much. -
Sorry buddy, I was having a laugh at your expense, that wasn't very mature of me. I know you know what your doing, I've seen you around these forums,I just hope this guy that can't get as simple as a type c PCB doesn't emulate you. It requires skill to be sketchy and not blow up!
oh god. This burns my eyes to see. Please, nobody do this. how expensive is a replacement evolv charging board? I have a 250C so idk what they cost, however, I know it can't be that much that you should run janky as this pic. Not even any type of protective measure from shorting on the pins against each other? I wouldn't run something this janky and sketchy for money. No solder mask over the points of connection? Not even any electrical tape to spare? Whew, God bless you sir.
I'm assuming you haven't read the entire thread because that's a literally verbatim what we've been talking about. Obviously every coil or coilless cup with embedded tungsten ribbon has it's limitations on the voltage+current delivered & how quickly You can deliver that current. In this specific case, we are referring to alumina ceramic cups with Embedded tungsten ribbon throughout the walls and floor of the cup for a "coilless" cup, Meaning it retains its flavor like you wouldn't imagine when compared to something that touches any sort of metallic heating element which just tastes absolutely disgusting. Because of the ceramic nature, these will absolutely crack sometimes even violently if you deliver over the suggested maximum current and add a faster pace EG higher TCR. @baltI've got myself sorted out, there is no need for this thread to continue on my part. I've figured out a simple enough, acceptable solution that gives me the results that I am looking for and I'm not having to Resort to using that ridiculous 55 watts limit they are having people use. I cannot imagine what a true 55 watts would do to one of these cups considering I can do a burn off end make the V five look Literally brand new again using only 38 watts and less than 2, 60 second sessions. I'm definitely getting a set of PID thermocouple probes but until then I've got a admittedly pretty nifty work around. I don't know if the temperature is accurate nor do I really care, the only part that matters to me is not destroying my hardware and achieving the hit density that I am used to which I can easily do now. Once I've thoroughly tested it, since it's an (As far as I know) completely original, new approach to this ridiculously unnecessary problem, I may release a how to thread likely on reddit as this forum is dead. @helpdesk I am stuck somehow logged in only on my laptop and for some reason it's completely denying any login from my phone so it's absolutely ridiculous to have to submit multiple tickets to the support center because their password reset system doesn't work. I've tried on three separate days over the last week and still have yet to receive a single email with the code to reset my password and I've also sent for emails to the support team here and have yet to get a single response from them @Wayneo As far as what you were saying, about all of my previous Arctic Fox coil info etc. being useful and I can import it to Escribe, unfortunately isn't possible. The manufacturers of the products we are referring to have us in every directional video and booklet as well as online reference material all point to setting up these products using one singular TCR value, a wattage level and a desired temperature peak. From there the software does all the lifting but it does not populate into a TFR value set In any way shape or form. They call it single point linear TCR which I'm aware you can replicate to an extent using this software the issue being that you'll be kicked into wattage mode no matter what your settings are. I've experimented with quadrupling the TCR value and adding an additional 17 watts on top of the manufacturers updated maximum wattage they say it can take and I still can't meet the TC requirement check implemented using that strategy. There is next to no data you can carry over from Arctic Fox Software to this software unless you were opting to ignore manufacturers directions and go ahead and make your own custom TFR for your material in Arctic Fox, that then would be in portable to use here but I guarantee you still would fail the ambient to 200 Fahrenheit in under two seconds check. The TCR from Arctic Fox used here in general on all 4 of my atomizers from this company, I've had to at least triple to even get it to produce a satisfying cloud. Again, I think it's just wrong product for the wrong usage. Definitely I've got nothing bad to say about my device. I am 100% keeping it and there are so many advantages aside from that one big disadvantage.. I've got close to 15 different mods running either Arctic Fox or Red Panda from single 18650 2 dual 21 700 batteries yet not a single one of those mods even the 2x 21700 device can last longer than my simple dual 18650 Therion 2. I'm completely speechless with the battery performance on these things it's so foreign to me to not have to swap batteries A minimum of twice in a day but I can not only not swap batteries, but end the day somewhere with 20 to 30% battery left. I guess that's that 97% efficiency rate they're talking about. Also the personalization is just on another level along with the quality of the device although that is more of a lost vape one up then it is evolv's. Let's just say I'm extremely glad I did not pick up the Paranormal instead of any of the cheaper options. Had I spent $300 on a Paranormal, I would have returned or flipped it, there is no doubt about it. However, a bit less than half that for the Therion 2, I can definitely live with. My issue is solved for now, plus can't even login anymore, so with that I bid you all a farewell and peace out.
So which do you agree with? Now I completely understand the relationship between TCR and tricking the device, the answer was it was relationship with room temperature that's the part I was not understanding and nobody could tell me what that answer was until you did. I appreciate so much that you took the time to get those screenshots for me, I'm not sure what's going on with my connection to divine tribe but if I click any of their hyperlinks, I get a 404 error and it's not finding anything so I literally couldn't get these or join their discord through the link no matter what. I'm really uncomfortable with cranking my wattage up to 55 watts that seems a Little excessive and definitely is going to take that lifespan way down on that cup. Currently the XL I'm running Is around 4 months old and still looks brand new on the inside after a burn off and cold resistance is still a 0.44 which is the exact same as when I first plugged it in. I suspect that this 55 watt recommendation or ceiling is going to result in dramatic resistance increasing and a lot of cracking of the cups. I've had a cup crack at 0.82 During a burn off set only at 40w and in the first 60 sec of autofire. So I'll definitely order a probe, like a proper one but without spending another 100 bucks i'd rather just stick with Arctic Fox at that point, but I found some decently rated temperature probes with display readouts for not too much on Amazon so I make that happen do you agree that the best course of action would be the material modification, then cotton bud test every say 2-3w? Also if I get a burnt Q tip before the device keeps TC, I would obviously just stop there and go back to using my cheap Arctic Fox mods that I have several of until a better way is put out by evolv. I suspect they're holding off on that because of the cricket and it's claim of two seconds until vapor production and five seconds before you can put it back in your pocket. They wouldn't want any plain old 250C to be able to do the same exact thing that the $300 cricket does so I would just stick to wattage mode I guess or go back to what I was using before I spent $170 on this paperweight! nah I'm Still extremely impressed by this mod but yeah I already have everything else I already have the theme that unlocks every single feature that they programmed into the board and I've done everything else stated in those screenshots just from my prior knowledge of how crucible style atomizer's work. At least I know I could always sell this mod, DNA chipped devices hold value better than any other brand, especially nowadays the lost vape DNA's, So I could always recoup at least a bit of my money in worst case.
divine tribe website has a random link to vaporninja and that literally just Literally tell you how to input a custom material in escribe. I'm just trying to understand the relationship between the 200 degree point versus where the TCR needs to be at that 200 degree point in relation to an overall TCR value of 200. Or does it not matter? Can I simply make it any acceptable value that's an upward curve from the first point? Obviously without going over there requested tcr of 200?
I hear you, I don't need another inaccurate device. I just want to have proof of concept before putting more money in this device
Thank you so much for this! 3 days of forum hopping and everyone is acting like it's this huge secret and its always referred to as the "material mod" but never delve into what the heck they are modding in the custom material. I did figure out it was because the v5 cannot get to 200f in two seconds, therefore failing TSM check which kicks us back to wattage. I also tried to create a fake mat profile to trick it but no matter what I do, that first point always has to stay at -100? i can create and move+delete any other points but that -100 degree starting point , I can't change its temp. I know I. probably sound like a fool here but could you please walk me through which point (obv needs to be at 200f right?) and the extreme difference in how TCR values are used vs the single value, linear curve Arctic Fox uses. I have those so dialed, sure the temp on screen might be +- 50f using a crude laser gun infrared thermometer but it doesnt matter since the vaporization is perfect. I know about the seedmass limited v5 and Hyperion? that he used like 5 platinum probes to create a 3D curve for the dna, I'm not looking to get my hands that dirty, however if i need to get a thermocouple probe and display unit, they aren't much for a singular probe with controller on Amazon. I'd want to see the thing even fire in tc at all before i dump more money on top of the cost of this therion 2 that is literally just a very fancy VW device for me right now. Could you give an example of how to plot the point that'll keep me in TC? I'd be more than happy to invest in getting accuracy as good as possible after I can at least use the device. Thanks for the quick replies man.
Correct, the XL cups in the newer base. I'm also having the exact same issues with my lightning quest. it's kiling me having to take out my 5 year old wismec or espion when I just bought a Therion 2. I know people have massive success using 250c chips with these but They also probably know the work around that seems to be kept so hidden.
I'm in the exact same situation as the OP. Using a multi material crucible style cup with inlaid heater ((3D heating), inlay is throughout the sidewalls & bottom of the crucible). The inlaid heating material is tungsten strip (I'm not sure it's a exact dimensions but that shouldn't matter for tricking the device). Then for the leads, Uses a tungsten high-temp slurry solder joining to nickel leads to the tungsten. I have seen this "workaround" Mentioned dozens of times across dozens of forums yet I cannot find a single person that actually says what this work around is? I desperately need to find out what this is I have a general idea since I've heard a summary of what it achieves I just am very new to DNA devices, literally just got my first one last week. An LVE Therion 2 DNA250c, Which I purchased specifically to fire these cups since before that I was using the comparably, wildly inaccurate and inconsistent Arctic Fox and even Red Panda on a dozen different devices. Those at least, stayed in TC mode but Let's just say they could be more than 100 degrees off target. So, it's pretty disappointing to say the least to spend almost $200 and see some of the most accurate temperature control in the world, yet not be able to use it on the atomizer I bought the device for simply because the element heats up 2 or so seconds slower than the FW allows. For reference, the heater can take a mfr recommended maximum of 38 Watts but preferably would like to keep it at 37 since I don't like running things at their ceilings and has a manufacturer recommended TCR value of between 180 and 200. The 180 value was on the prototype model of this same atomizer and the production unit, I have both by the way, recommends a 200 TCR in the official documentation it came with. Since I've tried 38 watts, admittedly even 40 watts for a very short time, it still could not make temp quick enough but it's absolutely meant to be fired using TC they just were primarily designed to be used for Arctic Fox & Other single TCR linear value devices, not multipoint or curve TFR which the DNA uses. I've quickly outgrown. It gets old quick running a bunch of five to 10 year old mods that cost 20 to 50 dollars so they feel cheesy and are horribly overpriced and almost impossible to get these days since they've been discontinued for so long. TLDR: I've given the specs and values for the crucible I'm trying to get to stay in temperature control with my DNA 250C is there any possible way you can point me in the direction of finding this material tweak that allows me to stay in TC mode while firing atomizers that don't hit 200F within two seconds? Please and thank you very much in advance
@James Hey, just curious, but has just about all development ended for the color boards? between no service packs in more than a few months and also hearing the CEO of Evolv quoted saying that you're turning your attention to firstly dry cannabis, then I guess expand further into concentrates (Cricket 2? hopefully not we get a less restrictive price) seems Evolv's shifting focus to new ventures. Nothing bad about it, I just hope there are enough people to continue with the boards we know & love, while going after these new projects. I personally don't use my LVE Therion 2 DNA250C for vape juice, it's my portable dab rig. I wanted a cricket so bad but the logistics of its price made it a nonsensical purchase. Especially when I have well. over 1k in 510 threaded pieces and parts. I know most boards are older now, minus a couple. Will the 250C get anymore love you think? I appreciate your time
