Everything posted by ZebOctets
It is indeed an increase in power, which gives more heat, I was not sure despite the tests. Thank you for your return, because of simplifying translations, understanding is not always easy. ๐ค
Hi, What does the "warmth" option correspond to in the "replay" mode, please? What effect does this have on the mode and my puff? I thank you in advance๐ค
monitor data different from the box
ZebOctets replied to ZebOctets's topic in DNA 75 Color and 100 Color
Ok thank you gentlemen ๐ค -
Yes, I have already read the manual, several times๐ , it is super well done๐ but with the translation into French I do not understand if the box gives an average or the exact temperature what a measurement. -
Thank you for your return. That would be possible...can someone confirm that?? aMirS ?? -
Hi, I'm vaping on a Thelema solo DNA 100C, I'm trying to optimize my salted butter caramel flavor, it's not easy. could someone explain to me why the temperature information is different between the Escribe monitor and my box, please? monitor : 190ยฐc (+-3ยฐ) Box : 184ยฐc
Not finding the option in your theme, I removed the Coil material option, which I did not find useful, to replace it with the power option, this allows me to give enough watts to heat up desired max, I find that it avoids the diesel effect, this effect of rising in temperature very slowly. If I understood correctly ๐ค I hope to be understanding๐
Thank you for this information, I had not understood the use of this option as you tell me. Yes, it is degrees Celsius. Another question : - I vaping with a single wire SS3165L coil, is it normal that I have temperature variations? - Is it normal that we can modify the holding power in temperature control mode only on the Escribe software, and we cannot access it in the theme?
Hi, I noticed this problem with the DS and Gold version. Yes, in "temperature control" mode, the desired temperature is set, but if the holding watts are too small in the profile, the desired temperature cannot be reached. In my SS316L profile I had: power 20 watts; Temp 200ยฐ and boost 70 watts, the box didn't want to go up to 200ยฐ with 20 watts, with the Escrib software I modified the 20 watts to 55 watts and the box went up to the right temperature. You cannot change this value in your profile. I may not have understood how it works
Hi, a big thank you for your work on this beautiful theme, it's a killer ๐ค I just have a problem, maybe I didn't find ๐ but I can't modify on my box (Thelema solo DNA 100C) the temperature maintenance watts in the "temperature control" mode, I can change the boost watts but not the sustain watts. I have to connect the box to the Escribe software to be able to modify the watts Is this normal?
