Adam_Aves
Everything posted by Adam_Aves
Hcigar vt75c not performing even close to my triade 250c
Adam_Aves replied to Adam_Aves's topic in DNA 75 Color and 100 Color
If I load settings from triade (working great) to escribe can I then copy that exact setup (settings) to the hcigar vt75c , (seems that will work just have not tried) -
Thanks, seems like an easy mistake to make. -
Thanks @Wayneo, I am pretty sure they are exact same material (I will triple check) and the resistance reads the same for the atomizer on both mods. Only difference I could see is room temp is 10 degress or so higher on hcigar. I was going to try case analyzer in the am -
Hi, where in escribe is case analyzer found? My triade 250c shows room temp of 74 degrees,my new hcigar vt75c shows room temp 84 degrees and the performance is not nearly as good in ss316l mode. I am just starting to troubleshoot. Thanks
Thanks Wayneo, thats a wealth of information. And appreciated. I have had very good TC today with a stainless steel build I made in the drop solo. Without manually locking. Im using mrbottomfeeders latest theme and I can see that the chip kind of holds the cold reading without it actually being locked. and just so everybody in here is clear this Triade is working amazingly well, best I have ever had. this whole time while I've been bugging about locking ohms I'm still at 60% battery, first charge. Yes this is the comprehensive answer I've been searching for. Thank you, as wayneo mention to me in the first reply he gave me to not lock there's some feature that DNA
Yes this is the comprehensive answer I've been searching for. Thank you, as wayneo mentioned to me in the first reply he gave me to not lock ohms manually, there's some feature that DNA does, "refinement". So as I now understand, once a temp sensing atty is put in at room temp no need to lock bcuz the dna chip will take care of all calcuations and use refinement, for example, to do proper Temp control. Edit: now I dont use any cotton, this is a ti coil on a ceramic rod with oil put directly on it, just so all is clear.
I just bought some wire from my mom and pop Vape shop, the proprietor who sold me my triade and has every mod known to man, and is a master coil builders answer to: "should I lock ohms on my temp sensing coils with dna". Was: "Of course thats how tc works by locking the cold resistance first".
Would you agree @Wayneo, and if say I installed a new atty and the triade asks "new atomizer" and I select yes, does that "lock" the resistance? " As stated above. Or is that just normal conditions ie: the dna chip is taking care of all the live measurements and the atty is not actually locked? Thanks
Look at my recent posts, some have said lock, some have said not to. And I was wrong I thought some of the replys im mentioning were mods. Im now using mrbottomfeeders latest theme so I can easily see all info. So would you guys (mods on this thread) recommend not locking temp sensing coils, but just installing them at room temp, and let the 250c chip take care of things? And in your experience how much would a coil have to "drift" ohms to lock it? I am using ti temp control. Thanks and my apologies for the one heated reply I had.
Good to know, I am sorry for being a wang then I was just fired up when I got some conflicting answers, your a solid dewd and these forums are not crap.
No need to yell, you said most mods here would say not to, so that was bad info dewd. These forums are really crap. Ill try to help when I can.
@Wayneo this mod and a few others are recommending to lock cold ohms, thats also what I know from my other non dna mods.
Thanks @zark, this is the answer I needed. Some mods here suggested never to lock (unless ohms float alot ) as the dna board takes care of it.
@DJLsb Vapes has an awesome theme that is helping me learn my dna 250c. He also has a YouTube tutorial for escribe. Highly recommend.
- 1 reply
- 1
Ok I see @lordmage Do you lock your ohms when using tc on the ti and ni profiles? And do you lock ohms when your using replay with Watts as material?
Thanks @lordmage That makes sense. Why do you choose material watt for your ss coils? Do you not like to use SS as material with TC for those? Ive noticed even with my ti coil that using: material watt and then replay works very well.
Hi @lordmage, I'm a little confused with replay but almost there I'm using a triple titanium coil with a resistance that doesn't float. Its .35 If if I use my first profile which is replay, and leave the material on Watt, adjust to a good known wattage (in this case 35 watt) get a good puff and save it. Then replay that puff, is it doing some sort of temp control (utilizing replay)? or do I NEED to change the material to TI in this replay profile for any kind of temp control? thanks
Do I need to lock resistance with replay?
Adam_Aves replied to Adam_Aves's topic in Replay and Atomizers
@retird I am really enjoying replay. It seems I am using stock profile 1 (watt) with replay on at 35 watt which works great with my triple ti coil. Question should I be going into the ti profile (5 , I think) and doing replay from there for the "replay style temp control" or is it best for me to stay where im at, I usually do 8 second puffs. -
help pls ohms question
Adam_Aves replied to poopy-_-'s topic in Manuals, Instructions, and Tutorials
hi, i had been using an arctic fox firmware setup where you have to lock resistance, so it was just weird coming to dna and it seems its best not to lock resistance( generally ) unless coil fluctuates or drifts alot. its working very well in replay, and for the triple coils mentioned above you can push them a bit more , 35 watts is good. These triple ti coils usually sit at .35 or .36 as my room temperature fluctuates. They usually dont move around to much at all though, I am thinking I will not lock and see the results. I am really happy to have this Triade 250 C, very satisfied already. -
Hello @Wayneo I saw some of your replies in the threads, helpful. can I ask, I have a Triade 250 c and some temp capable coils. Do you recommend not locking the resistance if the resistance cold stays about the same? And in replay mode with same coils is it best to leave things and not lock , thanks -
Hi, when you say "block" in your reply above you mean lock, right? And it is for coils that are temperature sensing (ss316) that im using. I am looking at themes, but want to learn a bit as I go, and make my own themes later. Im just wondering how to lock atomizer in replay (whether on mod or escribe) or if its even necessary. Thanks. -
I just got a triade, I used replay right out of box with a hvt Sequoia atomizer and it worked very well, as far as I know I didnt lock resistance. I did answer yes when it asked "did you just install a .35 coil". Do I need to lock resistance in replay?, and how to do it. Thanks.
