Anymore explanations on the "warmth" Option?
I am struggle as well with understanding. And it does only appear in replay mod is that right?
About the ohm that they get higher by the time is the SS steel which is used on the coil. SS will end with an higher resistance by the time as it get warmed up. Also the boost factor could influence the ending value. SS304 reacts harder/higher as SS316 from my experience. So i began to heaten up my firsts build on the usual atomizer with much less wattage and they stayed more in the range when i first read their resistance. SS will always raise in resistance thats why i can be used in TC mode. TC mode uses the resistance jump from the wire to calculate the heat. As there are no heat sensors on the atty/device.
So replay mod should be perfect here as it keep the ohm settings from your coil and throttle/raise the wattage until the ohm is reached again.
at least how i figured it out for myself
cheers A
