Bob R last won the day on May 31 2018
Bob R had the most liked content!
Bob R's Achievements
SS316L dual coil Fused Claptons 0.13 Ohms, been working fine and then just started showing 'OFF'. Might try a new build or different RDA see if thats it, Love my Goon though so will try tomorrow. Thanks.
Hi All, Can you please help? My LV Drone has started to display 'OFF' the second I fire it, I have the unit set at 90W 410 F and Temp dominant in Escribe. I have tried raising and lowering both Temp and Watts, Also Rebooted (uploaded) settings but still can't seem to find out how or why this is happening. Help and advice appreciated. Thanks.
Ni80 is not a Temp sensing wire, you need to use SS, Ti or Ni200 to enable replay. if you mix any of these 3 wires with Ni80 or Kanthal.it will also work.
Hi Nexolek, I have been advised to carry out the Thermal case analyser, upload that to the device then do the battery analyser and upload that also. The 75 is easy but the 250C and 200 are both dual 18650 so I only need to carry out the battery analyser once, (I only use Sony VTC5A's in my DNA Mods) then save the .csv and upload it both mods after first carrying out the thermal case analyser for each mod.
Thanks, Will start to set everything up now and settle down for a long wait/watch session.
Post deleted due to finger malfunction. lol
I have 3 Lost Vape DNA devices, 75C, 200 & 250C. I want to get them all set up perfectly but am not sure of what procedure to perform first. As the case temperature will increase when firing the mods then this will affect the internal resistance of the mod if my thinking is correct. Therefore it will impact on wattage and so affect battery performance. Do I run case analyser prior to running Battery analyser or vice versa ? I will start with the 75C as a single battery mod will take less time and I want to maximise battery usage and have all settings spot on (OCD I think). Any help and advice will be greatly appreciated. Thanks.
Thanks, it's just I remember getting great flavour from Ti and I have loads of wire left but was a bit worried just using 'Watts' to set it up, I know in my diagnostics I have the Temp set to 410 deg F so that would take care of that aspect i suppose. Will give it a go later.
Hi All, First off I am Loving 'Replay' on both my 250C and 75C, Thank You Evolv you did a GREAT job. What I would like to know is.... I used to vape in T/C using Ti wire, then I changed to 316L, I know using Replay it is set for power mode but if I want to use Ti wire again for some spaced coils do I need to upload the wire type profile from Escribe or does 'Replay' automatically sense wire type based on Ohms and Rise due to Temp/Power ratio?
OK, So WHEN is this NEW software for the 75C coming out?
Bob R replied to Joe M.'s topic in DNA 75 Color and 100 Color
Can anyone tell me where in SP 15 they have hidden the PK option? I believe it is to allow dubious coils to run in 'Replay' but cannot find it -
Hi Man, When you have downloaded the service Pack (15) just go to the Themes Tab- select {Default Theme} - upload to device- then go to General tab and check 'Profile 8' -
Hi Kressel, I did buy the 250 C (Lost Vape Paranormal) and am using it, it is a very good progression that is easier to use than TC, It also gives excellent flavour on my RDA's however my 75C (Lost Vape Therion BF) is a BF Squonk mod and the flavour is a little bit better but that is in T/C. I want to try 'Replay' on a Squonk mod with my favourite RDA and Juice as I believe it may be even Better! The Video stating Replay would be released for the 75C stated things would happen 'when everyone returns from Chinese New Year' and that was the middle of February. It is now almost the end of April, over Two months down the line and still no update! I believe it is a ploy by Evolv to create demand for both boards or otherwise why mention the '75C upgrade' till the 250C sales hit target? People will still want one or both of these awesome chips so it is really just advertisement of their new product. That said I still think Evolv are dragging their feet more than a bit and are starting to really annoy their Loyal Fan Base with these delays. -
If you watch the DslV video the guy from Evolv states ' he is using a SS316L Clapton which did not work well in T/C but is working perfect in Replay'
Simple builds and RTA's don't give me a great flavour so I tend to use complex with RDA's. Replay seems to be working with the exception of the first couple of hit when you have dripped, after 3-4 pulls it settles down and is great but you can change wattage but not select a Max Temp for that vape. I will keep trying though but am using up juice like nobody's business (LoL).
