rask116
  • Full Name
    Tony Morris
    Oklahoma
    Wismec dna 200, Vt250dna, 3x DIY dna200, 1x DIY DNA250, Thinkvape Finder 250c
rask116's Achievements
  1. Correction to above post I typed: "Probably due to the chip being able to do 300watts" which should have read: Probably due to the chip being able to do 400 watts total which of course, changes the temp ranges even if you don't ever go to or use 400, 300, 200 watts
  2. I got this reply from a ticket from the help desk which stated: "Connect the device to EScribe and from the top dropdowns try Edit > Timeline and see if it will let you go back to before it was changed." I ended up, however, trying a few other themes from the download section and found one that worked. "gauges". The only downside to this theme is that it is incredibly hard, if not impossible, to see while outside or in a vehicle. But it got me back to having the replay on all profiles. BTW, replay works in temp mode as it was designed to do originally, only later, after some software updates, did replay start working in watt mode or Kanthal. It wasn't originally meant to work in wattage or non-temp sensing wire. But it works on all vape wire now. Just make sure you have a good material .csv profile from wire wizard ( mind you that wire wizards profiles are for dna 200 chips, so some tweaking will need to be done with the .csv files for the 250c. IE: I use nothing but 317L ss wire and had to play around with the .csv file for a while to get it acting right with the dna 250c. worked without flaw on the 200 and 250 but it wasn't acting right with the 250 c. Probably due to the chip being able to do 300watts which of course change the temp ranges even if you don't ever go or use 300, 200 watts))
  3. IT WORKS! Yeppers it works on my Think vape finder 250c! Whoopie! Good job and thank you.
    First let me say, that for a Basic Default styled profile, I like this, it's awesome! The reason for 4 stars and not 5, is because of the (I guess) puff counter thing under the temp setting on the main screen. I'd personally rather have the voltage and amps show there. But I'm not salty enough (at all at present) with the Theme designer to attempt putting it in and taking what you have there out. I can't see or tell what that thing is on my Thinkvape Finder 250c I just got 3 days ago anyway. I like your theme simply because I can see the thing outside, whereas many of these offered themes here offered at escribe forum I can't see at all if I'm in my car or outside. But thank you for this. Works well so far.
  4. I see it's been 7-8 d days since the last post about the locking issue. I have the same issue as well. I downloaded the DNA250c-Gauges-1.4.1.ecigtheme last night and have been trying to figure out the issue and I'm not smart enough to find it. On the main screen, no matter what profile I'm running, I can't get the lock screen to happen with the default 5 clicks. I set it to 3 clicks in escribe and can get it to work with 6 clicks from the main screen. But it'll unlock with 5. I then go to the system screen from the main screen and get the same thing. 6 clicks to lock. Though I have 7 DNA devises, they are all 200's and 250. My new mod is the LostVape Finder 250c. Seems to be a different beast to tame. Yes, all my profiles have support replay toggled but not puff saved, playing. So does anyone know the fix? What could I have sat up or not set right to cause this? I don't dabble in the theme designer yet as I have no clue about it yet. I did try on the default profile and messed something up so got this and just uploaded it to my mod and just set the basic parameters like profiles, battery atc.
  5. I also submitted a ticket, hoping to get some help that way too. Ticket ID: WQD-EP2-Y9XT
  6. Only reply I have is... Welp I lost my replay too. Yes it was working great before............ I went into theme designer and changed the .1 increments to 5 and changed the background to the hump mountain bg that came with escribe, Didn't think I did anything else though. After getting frustrated, I came here, found this thread, saw the paranormal 250c link, so tried that. Nope didn't work, so tried to restore defaults. Nope that was a no go too,...so really got adventurous and whet to the themes here to try one of them, to see if maybe one of them would somehow help. Nope. so went back to default and basically all I have is a 2 day old Think Vape Finder 250c with no replay, Great! Not! I own 7 dna devices 4 diy ( 2x 200 and 2x250) and 3 china manufactured ones, 2 of them are 200s and the other a 250 and now this 250c. I had thought I'd be pretty salty in escribe with this one , but have learned that I know nothing now. HELP! Everything here in this thread so far offered as advice hasn't. worked for me. I'm very lost now,, ps: I downloaded the international version of escribe and installed it before I ever plugged the device into my computer . I saw no where in escribe to "ask for ohms for every profile". Well no where under the general tab or on each profile page I didn't see it,
